Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I have Konica Minolta bizhub 350. My computer is already detected bizhub 350 but not print Thanks
    President:
  • Konica Minolta Expert
  • 347 Answers
When your computer has detected the photocopier machine, then the next step is to install the drivers, which you may find in CD-ROM or you can Google it.Drivers are easily available on the internet.Download the drivers, Install the printer and then execute print command.It will surely work. If you want to use it as a single pc printer then its ok, if you want to use it over network, as a network printer, then you have to assign IP address to machine.
Posted on Dec 18, 2014
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
Posted on Nov 19, 2007
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
Can't print pdf's from my Macbook to the konica minolta 350
do any other document word, etc. print? Try this site for most up to date drivers
Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 18, 2015 | Konica Minolta bizhub 350 All-In-One Laser...
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Sep 01, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Hi! I just bought a Konica Minolta Bizhub C350 that prints very slowly. It takes 30-40minutes to print a pdf document of 2.12MB (20pages). I have already checked the pdf/printer options and it seems ok....
the Konica Minolta Bizhub C350 is by nature a slow printing machine the standard memory that the machine comes with is only 256mb and it can only be upgraded to 512mb . but there are some things you can do to help speed it up a little.
touch the utility/counter button
touch admin setting on the touchscreen
enter the admin password
touch system setting
touch output setting
touch print/fax output settings
touch print
select between page print and batch print=select page print
exit all the way out of admin mode then reboot the copier
tests have shown that this changed a print job from taking a little over 2 minutes to taking about 9 seconds to start printing keep in mind this is definately not the fastest printing machine on the market hope this helps thanks for using fixya
Oct 23, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
What driver do i use to scan using windows 7 for konica minolta bizhub 350 just upgraded computer and it won't scan now prints ok
I believe you must install the software from the bizhub disc and if that does work you can set it up to setup it to your email as a pdf
May 13, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 350 doesn't print at night.
Check the driver, you should have availability.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Aug 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Question about Konica Minolta Bizhub 350
click here for the steps on how to configure the bizhub 350 and here for the vista driver that you need to use if you're going to install it in a vista computer
hope this'll help you
ciao
Aug 26, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Slow printing of large pdfs
Sounds like you are just bogging down the Printer's memory.
Your best option is to upgrade the memory.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Printing from an IBM AS/400 to a Konica Minolta 350 printer
An HP5si PCL5e driver may work for just basic printing.You will not have any extras like finishing or dulpexing.
Oct 21, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
76 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
