Question about Philips Televison & Video
Just bought a second hand philips 20hf5474 with universal remote but no user manuel. cannot get into menu to set channels, clock etc
    Scholar:
  • 150 Answers
Hello philbarbara:
Here is the link for the manual for your Television:
"CLICK HERE"
It looks like this set has a lock for the menu which can be accessed only with the remote. Hopefully its not locked out.
But it also looks like you have buttons on top of your set. In which case you should be able to access the menu button from there.
As far as your universal remote goes, you might need to try a different code in order to control your televisions menu settings. Some codes only control on, off, volume etc. If you put the right code in your universal remote you should be able to get all of your remote functions.
You also might want to try watching out on Ebay for your remote that goes to your particular TV set. That would be the easiest way to solve your problem.
With the manual link I've provided for you, you should be able to solve this dilemma your in.
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Posted on Mar 26, 2011
  • PNiss Mar 26, 2011
    The buttons also might be on the side of the television set.
Program RCA F20352SF television to DVD player
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Aug 11, 2009 | RCA F20352SF TV
Muted on Cerain Channels on Zenith SE2795W TV
Somewhere in it's lifetime, a user has set the 'user preference' to 'mute' while this channel was active. I don't know your specific set, but most TV's need a remote to work 'mute'.
Second hand set?
[A] check all buttons on TV for a crossed-out speaker symbol, or
[B] buy a universal remote and select pin for your set. Then,
Try these:
ZENITH - 000,001,004,023,038,058,059,064,073,121,135,136,153
Oct 11, 2017 | Panasonic DMR-EH60 DVD Recorder/HDD...
Samsung DVD set up using Philips Universal remote SRU 5030/86
To get all the functions you need, a universal remote will not do - you need to get the OEM remote for the unit OR a remote for another unit manufactured around the same time since they usually employ similar frequencies and have similar functions.
Jun 16, 2017 | Televison & Video
Philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Jul 29, 2008 | Philips Televison & Video
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Universal Remote Codes
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
Jun 11, 2008 | Philips PM435S Remote Control
Remote codes for philips universal
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
Hello
Hope this helps :)
May 09, 2008 | Philips Universal PH301S Remote Control
Instructions please
Universal remotes are limited. Power, volume, channel and mute is often all you can get to work. Others buttons such as menu and source and video and antenna and CC (closed caption) will not work with any universal remote. I always recommend the original to my customers.
The original can be bought here:
http://www.replacementremotes.com/store/index.cfm
Mar 23, 2008 | Philips Universal PH301S Remote Control
Televison & Video Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
