Question about Jura Capresso IMPRESSA F60
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the inside of the machine to no avail Can anyone help?
  • tigerdw Mar 26, 2011
    I fixed this issue myself hours before and sent an email to inform you! The problem was nothing to do with cracks or the above, this is my third Jura machine and have had a great track record with all of them. It seems as though some coffee grounds had got wedged in the mechanism and jammed it. Managed to use a soft brush to clean it out and repeated the vacuum process. So was glad to get my cup of coffee after. Thanks anyway
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Posted on Feb 29, 2012
  • 5,370 Answers
The drip tray should fit easily.Its just a placement on the base part.It fits easily.If its not fitting properly, then may be its mechanism is got cracked or you are not inserting the tray properly. Remove the tray out and match its corners to the coffee machine, then place it carefully.----------
Also check the under side the lower base side of tray, if there is something got loose or cracked, then that can be the other possibility of drip tray not getting fitted properly.-------- Check out.Keep updated.Thanks.Helpmech.
Posted on Mar 26, 2011
  • raj somaiya Mar 26, 2011
    Thank you for this good updated.Thanks.Helpmech.
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
I have a Jura Impressa C5. My drip tray mechanism is broken because I pulled out the tray while it was still operating, and a piece of plastic of about 7.5cm x 17 cm (3 in x 7 in approx) came off and...
This is the used grounds blade that makes room in the used grounds container. This is fixed to the brewing unit, and can not be reassembled without opening the machine. If you make sure to check your grounds container often, you really don`t need to put this blade back. Just make sure that the container doesn`t overfill.
Apr 27, 2011 | Jura Capresso IMPRESSA F60
Cannot install tray with ground basket installed, after removing. Mechanism is blocking the ground basket when the tray is slid back into the unit after emptying.
Try putting a container under the coffee spouts and pressing the rinse button. This will usually free any coffee grounds that may not have been expelled into the grounds basket from the last time the machine was used. The grounds can get stuck and block the slide path of the grounds basket.
Dec 23, 2010 | Jura Capresso Jura / Capresso IMPRESSA J5...
The tray will not fit back in the machine, its jammed and I don't know how to reset the machine on a Jura F9
This happens when the try is removed before the brewing unit resets fully.
To fix is easy.
  • Remove tray,
  • Lift off grinds bin from the tray
  • Return tray to the machine with out the grind bin
Now you need to reset the brewing unit this is done by either
  • Starting a rinse cycle
  • Powering off and then on
Once you have don that return the grinds bin to the tray and it will go in.
Oct 28, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura Capresso IMPRESSA F60 Logo
1,945 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
