Question about Technics SL-1200MK2 Turntable
My headshell will no longer lock onto the tonearm locking nut both my headshells lock on my other turntable. Does this mean i have to replace the tonearm
    Champion:
  • Technics Expert
  • 271 Answers
Hi, there is no need to replace the entire tonearm. I can supply you with the very end part which is held in by two screws. Styluscity@gmail.com. John
Posted on Apr 27, 2011
How do i find a turntable cartridge technics headshell SL-BD22
The SL-BD22 turntable's tonearm does not have a headshell. It takes a P-mount (otherwise known as a T4P) cartridge which plugs directly into the end of the arm.
May 21, 2014 | Denon DP-47F Turntable
Hi there, I have just replaced faulty rca's on my
Possible internal damage on the unit, please replace back with the old unit to confirm if the connection pins and wiring are working. If so you need to check with a new unit.
Aug 02, 2013 | Technics Audio Players & Recorders
TECHNICS SL-1650 RIGHT CHANNEL IS OUT.
No continuity means you have an OPEN, not a short.
Before you tear the tonearm apart, check each of the 4 contacts for continuity to the various RCA cable conductors. Two will be to the outer conductors (ground) and each of the other two should have continuity to one and only one center conductor, NO grounds.
The wires are very fine and crimps may have failed, or oxide has built up on the contacts within the headshell. Sometimes repeated plug/unplug action will clean them up.
Nov 27, 2009 | Audio Players & Recorders
Tonearm Weight, Good Replacement Stylus, Gain level
Most good turntables will track with weights between 1.25 and 1.5 grams. Any more than that and you are putting alot of pressure on the needle. Experiment a bit and make sure that the needle tracks well and that the sound is good. The less weight you use, the longer the needle will last and the less wear on the record.
Dan
Aug 11, 2009 | Numark ttUSB Turntable
Missing Parts
You need a headshell unit (which is needle etc for the front of arm)
also the felt pad.. also known as a slipmat, you can pick up at dj supplies shops or on ebay..
I need a counterweight myself as my ION turntable also had missing parts when I got it as a gift.
I found a headshell on ebay which is perfect...Turntable Cartridge and Headshell Black DJ DISCO USB on eBay (end time 08-Sep-09 00:11:01 BST)
I havent yet found a counterweight..I hope I will!
Hope this helps in some way..
Kate
Feb 26, 2009 | ION Audio iTTUSB Turntable
Headshell for Denon DP-45F Turntable
The PCL-30 does not look like a standard headshell. I doubt the above answer is correct.
Aug 02, 2008 | Audio Players & Recorders
Intermitant channel down
Hey, I'm having the same problem. I found this with a little help from a small site I found called Google:
http://www.divdev.fsnet.co.uk/repair3.htm
Here's what he suggests. I have no clue what it means but I'm sure that it cane be decoded with some manuals:
Technics SL1210 , 1979 ?
Intermittent loss of one channel.
The headshell was slightly loose on the tonearm
and moving inwards would cause loss of one channel.
To remove this arm undo the slotted lock ring at the very top
of the arm pivot and undo the central pin. The arm
with jiggling can then be removed assuming enough slack in
the signal wires. Undoing the 2 watchmakers screws near
the headshell allows removal of the 4 pin connector.
Presumably the wires inside the tone arm at this connector
could touch the inside of the tonearm and lead to
break in sprung connection. Placed a bit of brass shim
in the slack area and pushed back in to wedge tight.
Also removed the soft washer on the plug shaft of the headshell.
May 26, 2008 | Technics SL-1210 Turntable
Technics Sl-1210 MK2 GOES MONO
Check to make sure you have a nice solid connection on your tonearm from your cartridge. The problem is either your tonearm or your RCA (red/white) cables.
Neither are easy repairs, unless you have soldering skills/experience. The tonearm replacement is the more difficult and more costly of the two.
Parts for the unit can be purchased HERE. If you have any questions about testing your unit on the exact cause, please feel free to give our TECHS a call - they are available 24/7 for your convenience @ 1.866.668.1596 ext 1
- DJ PRO LAB
www.DJPROLAB.com
May 08, 2008 | Technics SL-1210 Turntable
Sound problem
first thing to do is take the left and put in in the right, do you get sound on the right?
now take the phono cartridge wires and move the left to the right and right to the left does the sound move or stay same place. if they move with or not tells you if the cartridge is bad or phono plugs. if they dont move it's the phono plugs if the does move it's the cart.
Jan 28, 2008 | Technics SL-1200MK2 Turntable
Technics mk2 tone arm replacement
once you soldered to circuit board place - this might help Advanced Tonearm stuff Tightening the suspension on your tonearm Some TT's have tonearms which seem to be loose. If you grab the tonearm and pull it gently back and forth and it seems loose you can tighten it. It shouldn't move at all. A loose suspension can severely affect it's performance - from jumping needles to binding. It's pretty easy to tighten the suspension. You'll need a small flat screwdriver and a large one. Use the large one to loosen the outer locking screw on the top of the pivot point. Now use the smaller screwdriver to loosen up the smaller screw. Put a drop of oil where the bearings are (under that top support on the other end of the adjustment screw) so that it doesn't bind. Now tighten the small screw slowly until it just contacts the bearings. Adjust the tightness so the tonearm doesn't wiggle if you pull on it but leave it loose enough for the tonearm to pivot freely without binding. Adjust carefully and don't overtighten otherwise the bearings will be damaged! When done, tighten up the locking screw. Tightening up the headshell locking ring Have you put on your headshell, twisted that knurled tightener at the end of the tonearm as tight as possible and have found that the headshell still moves around? What will happen is that the headshell won't sit parallel to the record but may be tilted as a result of twisting of the headshell. This usually occurs when you change headshells a lot or if you've had your turntable for a while, and can contribute to needle jumping so here's what you do to fix it. First read 3.2 on base disassembly. Remove the rubber base. There will be this big piece of hard black plastic covering almost everything. You'll need to remove it. To remove the tonearm assembly look for three screws (all formerly under that black plastic) and unscrew them. Be careful not to drop the tonearm when you remove that last screw! Now, remove the tonearm assembly from the rest of the 1200, and look at the bottom of the tonearm where the headshell is put in. There will be two tiny philips screws there. Get a jewelers screwdriver of the CORRECT size and tighten those up. Put the headshell on and try wiggling it to make sure everything is right. Now put your tonearm back on and close everything back up. hope this helps peace DJ Nyce
Jun 14, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
173 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
