Hi my washing machine service light came on during a wash? What does this mean?
    Brigadier General:
  • 6,277 Answers
As you do not say the make and model I am having to guess!
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 26, 2011
My kenmore elite 796 4051 will not spin during the wash cycle
quite probably the timer . best to call a local service man
Feb 26, 2015 | Kenmore Washing Machines
Loud clunking noise during wash cycle
Hi What machine is this? and is there play on the stainless steel inner drum?
Mar 11, 2013 | Washing Machines
Simpson encore 605 fault code are as follows during wash process stop suddenly, strat to beep and all lights are gone except the Maxi light . It flashs while beeps
Hi, my Simpson encore 605 wash machine wash on the half way keeps beeping, and the maxi is keep flashing. What kind problem it is?
Cheers!
Feb 12, 2012 | Washing Machines
Hi i have a whirlpool washing machine that keps coming up with a F05 on display with all lights flashing what does this mean please?????
The F5 error code means that during the wash cycle that the computer didnt see a rise in the water tempature...that means that their is a problem with the heating circuit in the washer,it could be a problem with the heat element,thermostat,or control board that wont let the water heat in the wash cycle.
GENE
Sep 08, 2011 | Whirlpool Washing Machines
My washer is messing up it wont finish washing, theres a DR that shows up whats that mean?
it is a code 4rm the washer that simply means error during washing ,troubleshoot panel and if it persist call ur service engineer
Jul 07, 2011 | GE WSM2420D Unitized Spacemaker Washer /...
Maytag MAH8700 AWM will not spin during rinse cycles
As you said in the question you are washing machine need to get services during rinse washing machines should spin.Try selecting only rinse option only.If it does not spin means just services it will be fine.Thanks for you are question.
Jun 17, 2011 | Maytag Washing Machines
Washingmachine tub spins during the wash cycle
If it's a top loader it sounds like the spin pall on the transmission is stuck, which would mean new transmision
Aug 06, 2009 | Whirlpool Washing Machines
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 13, 2008 | Danby DWM99W Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
