Question about ASUS P4S533-MX Motherboard
I have a p4s533-mx motherboard with 1.7ghz intel processor, my system had 1gig pc3200 and 256mb pc400 at 400mhz ddr1 ram, now my system suddenly wont pick up the 1gig ram card, only beeps when powered up and screen dont start, I am now resorted to use the 256mb ram on its own
  • 26 Answers
BUY DIFFERENT RAM OR REBALL AND BUY NEW CHIPS SOUNDS LIKE YOUR RAM HAS FAILED TRY STICKING THE RAM UNDER A HEAT GUN AND MOVING THE HEAT GUN BACK AND FORTH WORTH A SHOT JUST SEARCH YOU TUBE FOR REFLOW AND YOU CAN TRY MOVING THE 256MB RAM STICK TO THE SLOT WHERE THE 1 GB WAS AND SEE IF IT BEEPS OR NOT IF IT BEEPS IT MAY HAVE PROBLEMS WITH THE RAM SLOT ON IF THAT IS THE CASE AND THE 256MB STICK IN THE 1 GB STICKS SLOT BEEPS EXAMINE THE RAM SLOT WHERE THE 1 GB STICK ORIGINALLY WAS AND SEE IF ALL THE PINS IN THE SLOT ARE ALSO SEE IF ANY ARE BURNT BENT OR BROKEN IN THE CASE IF BENT PINS IN THE RAM SLOT THERE ARE HOLES THAT POP THE PINS OUT USE EXTREME CAUTION IF YOU WANT TO POP BENT OR BURNT PINS OUT THEN PRESS THEM BACK INTO PLACE AND IF THERE IS A PIN THAT IS MISSING WHERE THE PIN SHOULD BE PACK THE PIN HOLE WITH ALUMINUM FOIL WHEN FULL PRY THE ALUMINUM FOIL WAD IN THE PIN HOLE WITH A NEEDLE EVEN WITH ALL THE OTHER PINS THATS ALL THE ADVICE I HAVE ON THE SUBJECT ENJOY
Posted on Mar 26, 2011
  • ASUS Master
  • 32,281 Answers
The RAM modules may not be compatible with each other.
Try using the same make RAM modules.
Try Installing the 1Gb RAM module without the 256Mb RAM module.
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
Sep 05, 2011 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
I have pc p4 3.06 intel processor and i hav now DDR1 RAM in my pc can i use ddr2 ram by removing ddr1 ram will my motherboard support ddr2 ram
Sorry but you cannot interchange ddr1 for ddr2. They are different kinds of RAM, and your chipset (865GV) can only accept ddr1. If you want to use ddr2, or even ddr3 then upgrade to a newer motherboard.
Mar 09, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
How much ram and what type
From the manufacturer's web-site:
http://dlsvr.asus.com/pub/ASUS/mb/sock478/p4s533-mx/e1221_p4s533-mx.pdf
download the User Guide (a PDF) and scroll-down to the SPECIFICATIONS section, to find the exact answers to your questions.
Aug 02, 2010 | ASUS P4S533-MX Motherboard
Asus K8U-X motherboard,which ram memory , and processor support?
hi..for this mother board model asus K8U-X only same brand Processor u can oly use.Like if u use Sempron made by AMD only AMD Processor for that board.Memory support is DDR1 PC400 1gig up to 2gig...good luck and Have a Nice Day..
Jun 14, 2009 | ASUS K8U-X Motherboard
Can i use ddr2 ram in my pc inplace od ddr1 i cn purchase pc 07?
Hey there, Check for the slots given on your motherboard, whether all the slots are same; However a motherboard can support only one type of module either DDR1 or DDR2. your motherboard has only DDR1 slots. You cannot upgrade DDR1 to DDR2 cause the Memory Module or notches are different than eachother. Gimme Acknowladgement by rating me. Thanx - Romy Decostza
Jun 09, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
SYSTEM DOESN'T BOOT UP, GET LONG STEADY TONE WHEN SYSTEM STARTS
please check the system memory (RAM)
remove them and carefully clean in mouth with a clean A4 white sheet
or change the memory if possible...... and if problem still occur, please check the system processor too...
to check if the processor is functioning, remove the heat sink on the processor and boot the machine placing your finger on the processor chip.
it burns your finger after a short sec. BUT this should be done in a controlled way and after the memory had been tested for
May 10, 2009 | ASUS P4S533-MX Motherboard
Hi i have a asus P4s533-mx and with a 3GHZ processor and with a geforce6600 (agp) and the games tend to freeze and i have to reboot my system?. any help please
It is the video card. Newer games are so graphic intensive that they freeze up the system if there is not enough video memory. You could try upgrading RAM but I had a problem running newer games until I installed a graphic card that had at least 512 mb video ram onboard. Hope this helps.
Jan 10, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Intel D865GBF Ram related questions
here are the specifications of *********** board go through it...
Processor Support Intel® Pentium® 4 processor, Intel® Celeron® D processor and Intel® Celeron® processor in the 478-pin package
Note: It is important to verify supported processors before using this Intel® desktop board. Supported front side bus speed 800, 533, and 400 MHz Integrated Graphics Intel® 865G Chipset with Intel® Extreme Graphics 2 Chipset Intel® 865G Chipset AGP Connector AGP 3.0 (4X & 8X Speed 1.5 and 0.8 Volt Only) Memory Type Dual Channel DDR 400 MHz (PC3200), 333 MHz (PC2700), and 266 MHz (PC2100).
Note: Be sure to review important memory and system bus speed considerations before using this Intel® Desktop Board Max Memory Capacity of up to 4 GB Memory Slots 4 DDR DIMM Sockets Slots 6 PCI
So it will support DDR2 and you can upgrade upto 4GB...
Sep 28, 2008 | Intel D865GBF Motherboard
ASUS P4S533-MX Motherboard Logo
120 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
