Question about Panasonic Televison & Video
Color patches on my panasonic lcd rear projection tv
I had about six green spots and two blue spots about the size of baseballs. Panasonic came out and fixed this for me for free!! They said they "reprogrammed an eprom". I bought the TV in Nov. of 05 and this is Jan 09. Go Panasonic!!
Posted on Jan 18, 2009
I have colored spots appearing on my screen when the TV is on. The spots are 2 to 6 inches in diameter and always appear in the same locations at various places on the screen. The first spots I noticed...
the light engine (optical block) is failing. there are lcd panels and light filters in the light engine. the problem your having is that they over heated and the image is burnt into the lcd or light filter. my be caused by a failing fan or just it's life span. the lcd panel or light filter are done for. you can keep calling panasonic and bug them over and over and they may send you a new tv. sony sent me one after 5 phone calls. i had the same problem. hope this helps.
Jan 14, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
My rear projection TV has color spots in the picture, most noticeable on light color picture
What is the make and model of TV. If it is a Panasonic that has different colored spots such as pink, blue etc. Then you need t6o contact Panasonic as this is a memory reset that they have to perform on the LCD driver board. Other brands of LCD projection sets that have spots that appear all over the screen mostly on white back rounds are almost always dust that has settled on the LCD panels. This requires a technician to clean the LCD panels if possible.
Dec 17, 2009 | Hitachi Televison & Video
TV HAS COLOR BALLS A LITTLE LARGER THAN GOLF BALLS, COLORS VARY, RED, GREEN, BLUE, ETC. THANK YOU.
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Panasonic or look for your light engine online.God bless you and your house!
Nov 17, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I might have issues with my color wheel, Im bnot recieving a picture with full color!
if tv is lcd it has three color filters which can be damaged by heat.If it is dlp then it has a colr wheel which spins.they are located in the light engine.alcd tv has 3 lcd panels a color filter(red green or blue)is mounted behind panel coloring light going through lcd.prisms combine pictures before going through lens. If color burns off of filter then color of picture is affected
Oct 19, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Our Panasonic Rear Projection 65' TV all of a sudden started having color problems. The color seems to be greenish with a line going through it. Any help would be greatly appreciated,
Is this a rear projection DLP LCD TV ? If you have a light engine in it , it sounds like it is going. I have a 60 inch Zenith that had a Blue Haze that kept growing and growing, tuned out to be the light engine was failing which after all was said and done it was a $3000 repair. Lucky I had it done under warranty.
Sep 17, 2009 | Panasonic Televison & Video
Panasonic pt 52lcx66 won't turn on
Sounds like the light engine. Is this a DLP or LCD rear projection? Did you see any patches of color any time before the problem with the really dark screen. Please rate my answer and let me know what other questions, Tech Malick
Jan 31, 2009 | Panasonic PT-52LCX66 Projection Television
Panasonic PT50LC14 Rear projection LCD - too much green
Had the same problem today. Thought is was my bulb. Replaced it but still had the color problem. Replaced the cables between cable box and TV and no more problem!
Jan 22, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic 56" projection color problems
there are so many technologies for the projection tv's ever one has their own caracteristic faults with out you mention the technoligy used on your tv will be deficult to help you but assuming is a lcd projection you must have a problem with the optical block the repair will be expesive if you do not have a manufactuer warranty for it
Jan 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Color spots on 61" LCD Panasonic rear projection tv
had the same problem on my 52" LCD rear-projection Panasonic,
contacted Panasonic support (number is on their website) and after
several transferred calls, they set up a service call with an area
service rep, who callled the house that evening to confirm appointment.
He came to the house, removed the set back cover, and installed an
EEPROM upgrade, problem is fixed and was told problem will not re-occur.
No cost due to Panasonic extending the warranty to fix known issue with
sets. (Mine was over 3 years old).
Mar 11, 2008 | Televison & Video
Televison & Video Logo
288 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
