Question about Bosch Dishwashers
I have a Bosch diswasher model SGS44E12EU it is not filling up with water when turned on and so the cycle does not work.
  • 1,527 Answers
Hello, check the pump first make sure theres no water left in the machine if ok then check water supply to the machine if this ok then the cause could be the water inlet values on the machine make sure they are not blocked hope it helps
regards
shaun
Posted on Mar 26, 2011
Bosch diswasher model no.She3ar72uc/22! It gives me a code E-24!!! How can I get rid of that code to get my dishwasher to work?
theres either a problem with the drain pump or the re-circ pump is drawing too much current, if the error appears at the start before it fills with water and there is no water left inside the unit it is the re-circ pump, if its not draining water its a blockage or a faulty drain pump
Jan 10, 2017 | Bosch Dishwashers
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Bosch diswasher,model Sms68m02AU trips circuit breaker
rcd units trip from the milliamps that are in a short
it trips the rcd to prevent electrocution and acts in nano seconds besides being a circuit breaker for excessive current
the trip can be from moisture allowing a current leakage to ground or some other simple operation
I suggest that you get in a qualified electrician / bosch service technician to find the reason for the problem rcd
Sep 15, 2016 | Bosch Dishwashers
Dishwasher starts to fill, then displays watertap error.
Not enough information to answer. Need manufacturer and model number before we can help.
Oct 30, 2015 | Bosch Dishwashers
BOSCH SGS44E12EU/71 DISHWASHER LEAKING WATER INTO TUB
see this causes:
Main tub seal
if your machine is mounted horizontally the pump must be replace.
but if you have vertical machine follow this step:remove the lower rack+spray arms+spray arms support+wash /drain impeller see the diagram, then replace the seal.
Door gasket or seal
replace
Water-inlet valve
water inlet valve, leaking , replace.
Hoses
replace the clamps+hoses.
see the diagrams.
God bless you
Jul 11, 2012 | Dishwashers
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
146 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
