Question about GPS
Mitsubishi pajero GDI V6 3600 ENGINE NO 6G74 - GPS
  • 57 Answers
SOURCE: Mitsubishi pajero
It should be on the cyllinder block just below the head
Posted on Aug 27, 2009
SOURCE: Mitsubishi Montero/Pajero ECU Ignition Wiring
my jeep is are not charging whet can do for me i replace the alternator i put the steter coile but not charging plz reply
Posted on Apr 05, 2010
SOURCE: mitsubishi pajero gdi 3500 year 1998. vehicle not
I have a similar problem. It runs a while from cold and then just cuts. I have have changed the TB twice now with no change. I cant afford a new TB. Did you find a solution to your problem?
Posted on Nov 14, 2011
rwwood81766
  • 3783 Answers
SOURCE: diagnosis of APS Sensor on GDI Mitsubish Pajero
You really need a scan tool to diagnose this problem.
Posted on Nov 17, 2015
emissionwiz
  • 79851 Answers
SOURCE: Where can I find the high pressure pump on and the Mitsubishi pajero GDI and the fuel pressure sensor?
I don't think there is a pump, it is done with engine oil pressure at the injector.
Posted on Jul 12, 2016
Jul 12, 2016 | Mitsubishi Cars & Trucks
Diagnosis of APS Sensor on GDI Mitsubish Pajero
Nov 17, 2015 | Cars & Trucks
Mitsubishi GDI 3500 engine 6G74 it cranks but no spark any solutions
Got Mitsubishi challenger 6g74 there is no spark, changed the crank and cam sensor, fuel is coming but still no spark. please help
Apr 24, 2013 | Mitsubishi Montero Cars & Trucks
Pajero V6 still will not start (6G74)
Did you erased the code manually or the code clear itself?
Feb 02, 2013 | 2005 Mitsubishi Pajero 3.5
Mitsubishi Pajero with 3.5V6 GDI Engine. After this vehicle has been driven, and is parked for 5 to 10 minutes the heat gauge rises rapidly to its maximum when the vehicle is driven again. After a sho
You must Run the scanner for to see which is the fault exactly. Maybe you have problem with the thermostat, clogged heater , low level water, radiator clogged. fan/water pum drive is slipping intelet or outlet water hose clogged, water pump defective., temperature gauge faulty, engine loose cylinder head gaster, engine block is cracked. leak hoose, radiator,etc.
God bless your.
Sep 28, 2012 | Mitsubishi Pajero Cars & Trucks
Mitsubishi Pajero Exceed 1997 Model Engine #6G74 GDI V6 3500,no power,I suspect its the engine control unit,I order the ECU,but still no power,probably its crankshaft and camshaft sensor.
I solve this problem with Mitshubishi Pajero GDI 6G74 like this: remove the two little filters from the high pressure pump and ,if necessary, insert a external gasoline filter.
Mar 24, 2011 | Mitsubishi Montero Cars & Trucks
Pajero gdi 3.5 v6 e-45w 6g74 v5a51 as problem checkengine lamp continues blinks and engine dont acclerates atall
dissconect the hot side cable for 5 minutes then conect it back on,it should stop blinking.
Dec 22, 2010 | 1999 Mitsubishi Galant
Mitsubishi pajero
Aug 27, 2009 | 1998 Mitsubishi Montero
GPS Logo
126 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
