Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
My bunn slushy machine has just decided to go crazy .........a message keeps coming up ...filter cleaned. another number comes up ULTRO40166 and ULTRO999994.... AND none of the press buttons work . I cannot turn it off... totally no buttons work I have to turn it off by unpluging the power. please please help.
  • cofe2u Apr 02, 2011
    Hello Ginko.
    thanks very much for your help.
    the electronic board was the problem and has been replaced .
    thankyou for your help Heather
  • 19,396 Answers
Hi.
That means that either the filter is defective, or that there is an electronic problem. If the machine has been programmed in Clean Lockout you may get the same message, but in that case you can access fully the menu to reset machine or to remove Clean Lockout settings (by choosing '-' in clean menu).
Please do the following:
  • Try disconnecting power and leave it off for one hour or so. This will reset the electronics and can fix minor problems.
  • If you have a spare filter, try replacing the Filter, otherwise call Bunn first (see below).
  • If the machine is responsive (display and button work) go to programming mode, and do a reset. Reset is usually called PM in Bunn machines menu (PM=preventive maintenance).
  • If all that does not work, call Bunn (see below). They will guide you through a master reset and following troubleshooting.
Here Bunn website. Choose your location/business and find contact.
Regards.
Ginko.
Posted on Mar 26, 2011
  • Ginko
    Ginko Apr 03, 2011
    Hi.
    You are welcome.
    All the best.
    Ginko
Setting constitancy of product
I think your Bunn machine is producing the 'ice frozen drinks" it was designed for.
May 18, 2016 | Bunn Black Flat Lid Ultra 2 Ultra Gourmet...
My Bunn coffee pot seems to pour out so quickly. The grounds come out the back and all over the counter and in the coffee.
I have had this happen when I used non bunn filters . perhaps they non bunn are too small thereby letting the water run over the top My bunn takes 3 minutes when it's clean to brew 12 cups .
Jan 12, 2015 | Bunn Coffee Makers & Espresso Machines
Bunn ultra-2 slushi machine not icying up
Make sure it's on ice, not chill or off. clean the rear filter and make sure there is at least 6 inches of space behind the machine for it to breathe.
Apr 19, 2014 | Bunn Margarita Machine Ultra 2 Slush...
Oil coming out of back of machine
it isn't oil, it's old, syrupy slushie mix and dust. the only oil in the machine is inside the hermetically sealed (cannot open) compressor. you have a front seal problem. the shaft seal in the front inside the evaporator (steel tube), and the cup-shaped seal between the auger and the evaporator. slush is getting inside the shaft tube and dripping through the inside rear of the machine. replace the seals, lube with a food-safe lube and refill.
Mar 04, 2014 | Bunn Margarita Machine Ultra 2 Slush...
Bunn won't freeze the drink, the drum freezes and ices over but 3 hours later no slushy.
clean the filter and condenser coils, leave at least 6 inches of space for it to breathe
Aug 02, 2013 | Bunn Margarita Machine Ultra 2 Slush...
Why does my ultra bunn 2 slushy machine throw off extreme heat
Check the filter in the back of the machine that and the coils are covered with dust.
Feb 19, 2011 | Bunn Margarita Machine Ultra 2 Slush...
Bunn vpr steams everything out fill hole and nothing comes through copper tube, even after cleaning tube and head.
Fill water tank until water comes out from sprayhead, THEN plug it in it should be OK.
IF the machine keeps blowing steam/keeps boiling the water, The thermostat is defective and must be replaced.
NOTE: If you don't use the machine for a couple days, UNPLUG IT. The water will evaporate if you don't unplug it.
Jan 13, 2011 | Bunn VPR Coffee Maker
I didnt get instructions with my slushie maker
Check under the commercial products link on bunn.com to download a copy of the manual.
Dec 30, 2009 | Bunn Margarita Machine Ultra 2 Slush...
I need the instructions for the slushie maker.
Check out your manual. Usually, a manual will have recipes for you to use. If you don't have the manual, you might want to look into contacting Bunn to get one (usually they can send them out for free!). Their phone number (according to their website, www.bunnomatic.com ) is 800-352-2866
Good luck! :)
Aug 26, 2009 | Bunn Margarita Machine Ultra 2 Slush...
LEAKING WATER
I had the same with a Saeco it was caused by a leaky boiler, after replacement, it was fine...
Aug 08, 2006 | Waring Pro WC1000 Coffee Maker
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
345 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
