Question about GE GSS22JER Side by Side Refrigerator
My freezer is cold, but my refrigerator is not. What could I do, or what could the problem be. I don't have the money to go out and get a new frige PLEASE HELPPPPPP!!!!!!!!
  • 2 more comments
  • Anonymous Mar 21, 2009
    GE GSS22JEPA WW - SAME PROBLEM, FREEZER IS RUNNING JUST FINE BUT MY FIRDGE IS NOT STAYING COLD. TRIED UNPLUGGING AND PLUGGING BACK IN, DIDN'T HELP. ANY IDEAS??
    GE GSS22JEPA WW MY FREEZER WORKS FINE BUT THE FRIDGE IS NOT STAYING COLD. TRIED UNPLUGGING AND PLUGING BACK IN, DID NOT HELP. ANY IDEAS?
  • pjowers2001 Apr 03, 2009
    GE GSS22JFPAWW refrigerator side not getting cold changed main board and evaporator fan still not getting cold on refrigerator side heater and thermostat,defrost fuse good the damper and thermistor door will not stay open tried to keep door open to see if that would help get refrigerator side cool no help need help bad .....
  • mymatuti May 06, 2009
    my freezer is full of ice and the refridg part is warm how do i chek the thermostat
    Problem Solver:
  • 5 Answers
1 - thermostat,defrost 12.60 1170024
2 - defrost heater [duel heater kit now ] 41.60 1399613
3 - (evaporator) fan with thermistor 61.50 914169
4 - main control board 158.68
these are the main causes for not working and in order
Posted on Apr 03, 2009
CHECK THE EVAPORATOR FAN
Posted on Aug 04, 2008
Freezer fine frige to cold
you must check the door seals are ok and if they are you might have a bit of compressor oil stuck in the condenser pipes somwhere this is a regular problem with alot of new fridges youll need to take it to the agents if thats the case
Mar 20, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Frige cool freezer warm
IS the compressor running and is it hot?
Dec 08, 2012 | Maytag MFD2560HES Bottom Freezer French...
Frige not getting cold but freezer working
INSIDE THE FREEZER ON THE SIDE IS A HOLE THAT LETS AIR FLOW THROUGH THAT MORE THAN LIKELY IS FILLED WITH ICE. SAVE YOURSELF A LOT OF MONEY AND REMOVE THE COVER AND THAW THE ICE. MAKE SURE YOU SEAL IT BACK WITHOUT ANY LEAKS.
Jul 28, 2011 | Refrigerators
The evaporator fan is blowing the freezer works fine but the frige don't,?? what else can i check?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 14, 2011 | Hotpoint-Ariston HSS22GFTWW (22.0 cu. ft.)...
I have a ge frige that the freezer works but frige is warm
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS22JER Side by Side Refrigerator Logo
290 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
