Question about RIM BlackBerry Storm 9530 Smartphone
When charging my blackberry phone its shows charging when i plugin my charger but later shows its not charging again
    Problem Solver:
  • 5 Answers
There might be a problem with:
1. Your charger
2. Your phone
3. Your charge port
4. Your adapter(if using one)
This can be a big problem and of you take it into the store where you got it, they should help you with all of your problems, of it's #2 or 3 they should replace your phone(granted it's under warranty/just purchased) otherwise you may have to replace the part or buy a new phone completely
Posted on Mar 26, 2011
Charger
man you have to repair it
because the failure is in charging base
there is detector to detect if the charger is connect or not these one are damaged or faulty
go to any trusted repair shop
Jan 10, 2014 | Samsung Galaxy GT-S5570
Bb bold wont charge
Welcome to the BlackBerry Support Community Forums.
Have you tried plugging the BlackBerry is different outlets or tried a different USB cord?
Does the BlackBerry show a charging symbol or is the LED flashing red or green?
I look forward to your reply.
Feb 24, 2012 | RIM BlackBerry Bold 9000 Smartphone
Hi, i have a blackberry bold 9000, i went out of town for a day and forgot my charger at home and my phone was running low on battery, later that day it died. When i got home to charge it i would show the...
Dead battery. Try that first.
If that's not the case. the battery contact terminal might be bad. Which is common.
Chances are, it's just a fried battery that needs to be replaced
Sep 10, 2011 | RIM BlackBerry Bold 9000 Smartphone
When my blackberry is plugged to a charger, it shows the charging signal for about a minute and then the signal goes off.sometimes it shows the charging signal for a long time but the charging meter does...
It sounds like you may have a bad charger. Try using a different cable or charging it through usb. if that doesnt work, then you may have damaged the charger slot on your phone and will have to get it replaced.
Jun 09, 2011 | RIM BlackBerry Storm 9530 Smartphone
One fine day after low battery indication i plugin phone for recharge, it was well connected and showing charger plugin indicator on phone. phone was also working but percentage of battery was not...
You can try with this procedure, Try to charge another battery in this phone with another charger, if the battery got charged then there is an issue with your charger and battery, if it gives the same problem, then you have to get fixed your phone from repairing shop or your cellphone service center, it seems that the charging IC of your phone is not working properly which needs to be replaced, they will check the whole motherboard of your phone, and will fix the problem, if the set is in warranty claim it as soon as possible .
If you require more assistance, feel free to reply to this post
Thanks for contacting FixYA! Regards, BA
Feb 11, 2011 | Cell Phones
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
My usb port is damaged on my blackberry can not charge it how do I charge the battery? I cant charge it via the usb port which is needed for almost everything. is there another way to charge my blackberry...
The only thing you can do is use another BB to charge up the battery, and then swap batteries. Someone usually has a broken BB (screen dark, sound stopped working etc) which they will give you for free..
Jan 01, 2010 | RIM Blackberry 8310 8320 8330 Curve 8100...
The battery on my blackberry 8310 went dead. I
ok so what u basically do is just keep the charger in the usb port. then take the battery out then plug it back in. this totally works!
Apr 01, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
When i plugin chargar mobile show usb connect
Insert your charger pin completely into the phone. Then phone will show charging now.
After also if problem not clear then you have to reset the seetings and try it again.
Thanks,
Rokr_E6
Jan 12, 2009 | Motorola Mobility ROKR E6 Smartphone
Phone won't charge
No you cannot use a motorola charger to charge an htc touch.
Aug 22, 2008 | HTC Touch P3450 Smartphone
RIM BlackBerry Storm 9530 Smartphone Logo
20 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
