The printer shows 49 Service error ....what do i need to do please
  • Office Equip... Master
  • 1,915 Answers
A printer model would have helped as I could post a model specific link, this just means you will have to do some of the work yourself. Follow these steps:
  1. Turn printer off and then back on, if it comes to ready, go to step 4.
  2. If printer has 49 error again, you will need to delete any outstanding jobs in the printer queue. Go to the printers folder and double click on the icon for your printer which will open up the printer jobs windows. Delete all print jobs and restart printer again.
  3. If printer comes to ready this time go to step 4, if not, unplug cables from the back of printer, restart printer. If ready now, good, If not, I will need model number, operating system and more detailed infor to give you more specific instructions.
  4. Click here and type in your model of printer. You then want to download the firmware upgrade, choose the easy upgrade option if it is available for you printer as it is a self running file that requires little in the way of user intervention.
  5. Once file is downloaded, double click and let it run, this will upgrade the built in operating system of your printer so that you should be able to print properly now.
Posted on Mar 26, 2011
Testimonial: "thanx u sorted it "
49 service error ff04
your printer driver is corrupt or the files your printing are corrupt- most 49.xxyy errors are down to software external to the printer. not sure?.
disconnect the printer from all network points and cycle the power - when it is ready perform a path print test ( found under the diagnostics menu on the printer itself ) and you will likely find no errors ( if by some horror of horrors you do get 49.xxyy error then you will need to replace the firmware chip - Very Very unlikely) -
what to do--
remove the printer and uninstall from the workstation - reboot the PC - re install the latest driver for your operating system downloaded from HP website
re connect the printer - print away !!
Jan 28, 2014 | HP LaserJet 4600dn Color Printer
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
Nov 24, 2013 | HP LaserJet 5200 Printer
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Our HP LJ3005Px shows the following error: 49.FF04 Service ne Error What can we do?
Firm ware error issue.If printer comin to ready mode try to up load form ware, no ready mode replace formatter
May 04, 2011 | HP LaserJet P3005 Printer
49.ff95 service error
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
Dec 08, 2009 | HP LaserJet 2420dn Printer
Service Error
The 49 series errors are firmware errors, you may need a new formatter pcb.
Nov 18, 2009 | HP LaserJet 5500DTN Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
49.FF09 SERVICE ERROR
Go to http: www.hp.com/support/
lj2410, www.hp.com/support/lj2420, or
www.hp.com/support/lj2430. Click
Download Drivers and Software.
Check for the latest firmware image
version at the bottom of the page. If
this firmware image is newer than the
one installed on the printer and the
printer can receive a firmware update,
download the newer firmware
upgrade.
if this fix does not work try removing memory from machine turn machine on see if issue perssist turn machine off replace memory one piece at a time (if you have more than one installed) testing printer each time if you put in one stick and it works then you put in the second and it doesnt the second stick would be the problem piece.. but usually on this machine upgrading the firmware will solve this issue.
Aug 08, 2008 | HP LaserJet 2430n Printer
Open Questions:
323 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
