Question about GE Microwave Ovens
The pressure regulator or is it gas regulator I'm nor sure. on my Americana gas stove has NAT. 4.0" LP 10.0" written on it. What does that mean?
    Brigadier General:
  • 8,909 Answers
Natural Gas pressure is to be regulated at 4.0 inches of mercury and Liquid Petrolium Cas at 10.0 inches of mercury pressure.
Posted on Mar 26, 2011
I am painting in my kitchen and it is recommended to turn off stove pilot gas so know combustion happens. I have a Tappan gas stove that says "electronic ignition" on it. How do I turn off...
If you have an electronic ignition, there are no open flames. So you are ok to paint. Just make sure to not turn anything on while the paint fumes are in the air and you will be good.
If you do want to turn off the stove, unplug it from the wall. To turn the gas off you will need to pull it away from the wall and turn off the valve behind it, if it has a valve, some do not.
heatman101
Apr 23, 2011 | Microwave Ovens
No gas is coming from the cylinder to the grill even though I just had it filled?
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Mar 20, 2011 | Microwave Ovens
Gas jets on stove keep going out after a few minutes
Your problem could be or probably is with the regulator...not enough gas pressure...
or you are out of gas....
heatman101
Feb 11, 2011 | Fisher and Paykel Microwave Ovens
Need to convert nat gas to lp gas have a in the counter cook top
Most manufacturers of gas appliances offer conversion kits to make switching between LP and NG fuels for ranges, dryers, etc. relatively painless.
First, you'll need to collect the manufacturer's name, appliance model and serial numbers. Then, contact your choice of either the place of purchase, or shop the part to authorized parts resellers in your locality or internet for the correct kit and best price. Use only parts designed for use in your particular appliance.
I hope this helps & good luck! Please rate my reply - thanks.
Feb 03, 2011 | Frigidaire Microwave Ovens
CANT GET HIGH FLAME IN OVEN
heatman101
Dec 25, 2010 | Microwave Ovens
On Dacor cook-top. LP gas, what is recommended pressure (inches of water) in manifold? Have one burner of 6 that blackens cookware.
For LP you should be right around 10" WC....to high of pressure will give too much gas and burn rich... and make the soot that makes the cookware black...
heatman101
Sep 14, 2010 | Dacor Microwave Ovens
How do i conv a stove from lp to natr gas
you will need to go to your gas supplier or local appliance dealer/parts dealer and get what they call a gas conversion kit,it will show you how the system is converted for your particular appliance type/brand
Jun 15, 2010 | Microwave Ovens
Hi! I am converting my Maytag oven to propane from natural gas. I've flipped the cap at the main (n to lp) and snugged down all the orifices at the four burners, so far so good. But I am not sure if the...
Hi Kim,
First of all, read and follow all the safety instructions in your installation and operations booklets.
If Maytag recommend that only a certified gas fitter should do this conversion, then follow the advice.
If you are a certified gas fitter you would know the answer.
There are too many variables to take into account for this type of conversion like altitude, propane pressure regulation, age and wear of the stove, state of repair of all supply pipework, proximity to open flames in the area like water heater pilot lights. Leaking propane is heavier than air and will collect at the lowest part of the home like the basement where the open flames might be.
So my best advice is to ask a certified/ticketted gas fitter to do the job or check what you have done and ensure that everything complies with all local codes.
"If in doubt don't" is great kindergarten advice for everything which is potentially risky.
I hope this helps,
jenni.
Sep 09, 2009 | Microwave Ovens
How to convert from lp gas to natural
Microwaves are electrical only.To convert a stove,range or oven the orfices must be replaced.Insome cases a gas regulater my need to be instaled depending on if your on high or low gas pressure
Jun 24, 2009 | Microwave Ovens
Microwave Ovens Logo
95 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
