Question about Microsoft Xbox 360 Console
My x box 360 keep saying open tray every time I put a game disc in.what can i do?
  • 767 Answers
Pop off the faceplate look inside the hole on the lower right side
of the cd rom drive if you see a yellow and white wire is a Dg-16d2s Philips
they cost around 35-40.00 new on ebay . If it's two white wires it's a BenQ VAD6038 6038.
Same price. Order it from ebay goto youtube and type" Xbox 360 drive replacement "
When your drive arrives remove the P.C. board from the old drive and plug/solder it
in the new one and it's fix . This is a sure fire-way to get your drive working.
option 2 . is to buy a laser for a ben-Q drive 20.00 and simply swap it out
but this work about 60% of the time since the spindle motor and worm gear motor
will some time be the cause .
If you have any questions please ask before you rate this tip.
Thanks
Rob
Posted on Mar 26, 2011
I put in a disc into my xbox 360 and i just keeps reading th disc and saying open tray, I open tray, put in disc and close tray, it reads the disk and just repeats message open tray?? Please help
You can do it yourself by opening the xbox 360 case and the dvd rom with a proper tools.. tighten with a screw (counter clock) right there!! (see the picture)
Feb 16, 2011 | Microsoft Xbox 360 Console
I put a x-box 360 game in the disc tray and it reads and then after that my x-box 360 says open tray. what should i do to fix this reading problem?
take and open the tray then blow inside hard Some time i use (AIR IN A CAN) to clean out that will do it
Let me know if this help
Jan 02, 2011 | Microsoft Xbox 360 Elite Console
My xobx keeps saying open tray then close tray then again open tray....it wont read any of my discs
Open tray error is very common for Xbox 360 users, it could be a permanent or temporary issue to check
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
http://gamingbox.wordpress.com
Oct 26, 2010 | Microsoft Xbox 360 Console
When i put a game in my xbox 360 it says reading then open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 19, 2010 | Microsoft Xbox 360 Console
Xbox 360 Console: disc is not working keeps saying open tray...
This just worked for me..... unplug all leads etc from the back of the console2_bing.gif, hold the unit 6inches from the floor (carpet surface - not a hard floor) the front of the panel facing the carpet and drop it........ If its still under warranty send it back - if not give it a go!
May 17, 2010 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at alexswierenga@yahoo.com ty
May 29, 2009 | Microsoft Xbox 360 Console
Disc wont read
Hi
Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
Regards
KreativeGeek
Aug 30, 2008 | Microsoft Xbox 360 Console
X Box 360 Won't even attempt to read disc
when i put a game in the xbox 360 it keeps on saying clean the disk whith a soft cloth
Aug 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
143 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
