Question about Music
My roland gx 700 is communicating with the computer but cant playback
  • Music Master
  • 5,603 Answers
In the computer control panel under "sounds and devices" check that the 700 is the default device for "voices" for recording and playback and also under the the "audio" tab.
Posted on Mar 26, 2011
How to connect Gk3 equipped guitar to Electric Piano or Synthesiser ?
A Gk3 cannot be connected directly to an electric piano or synthesiser. The 23 pin DIN connector connects the GK3 / GUITAR to a Roland guitar synthesiser which produces the synth tones . This unit can be connected via midi cable to any external keyboard or synthesiser...to produce different or varied tones from the external synth ........provided the devices are able to communicate with each other...see the midi implementation charts for each device for information....
Aug 30, 2015 | Roland GK3 Divided Guitar Pickup
At times during a performance the organ sounds drops significantly compared to the ensemble sounds, what could be the problem?
Has it always done that? It could be it just doesn't have enough power to play organ at full volume along side the ensemble.
May 25, 2015 | Roland VR-700 V-Combo 76 Key Stage Piano
Is a manual available for the Roland SN-700?
your best bet is to contact Roland directly. Their contact info is here-
Support Roland
Mar 17, 2015 | Roland Music
I'm trying to midi from Roland TD8 to Simmons SD7PK
You need to be sure they are both set to the same midi channel.
Feb 01, 2015 | Roland Music
Roland db 700 bass amp
Contact Roland Customer Support at (323) 890-3740. Customer Support is open Monday through Friday, 8:30am to 5:00pm Pacific Time.
Aug 22, 2012 | AMP Music
My roland br 1600 cd rec.studio is just over a year old.I have 4 songs currently on it (80 gb) and it says HD full.It cant be full ....I cant work because of this error...
Yep... the hard drive is 80GB... so if you have 80GB of songs (not hard to do) it is full. Purge some off to make space. Those must be either long songs or have a lot of high frequency stuff using a lot of data to store them or a lot of tracks per song. For stereo recording two tracks using computer I chew up about 1 GB per hour. If you have armed more tracks this could really jump up... and these units may not be as efficient as the new software PC DAW's. I would recommend purging existing songs to a safe media and then reformatting/initializing the drive in the unit.
Aug 18, 2011 | Roland Boss BR900CD Digital Recording...
When I plug the pedal in and play, the music is constantly sustained without me pressing the pedal. Do i need a new pedal ? Is the problem within my Roland ? Please help ! - I use a Roland 700 GX. -The...
1.Make sure you are plugged in to DAMPER (not FC1 or FC2) 2. Check to see if the notes STOP sustaining when you PRESS the pedal. If that is the case, first try turning off the Roland with the pedal plugged in and restarting with the pedal pressed down. 3. Press the EDIT button and scroll to Damper Polarity. See if it's set to Standard or Reverse. 4. If problem persists after all that, try holding the pedal jack into the Roland at different angles and then try the same with where the cable connects to the pedal. At that point, you can either attempt to repair the pedal or get another one.
Hope this helps, Stewart
Feb 28, 2011 | Roland DP-10 Damper Pedal, B-Stock
A 700 series Line 6 Variax,noisy hiss
The hissing is caused by a bad connection, most likely at the cable jack. Try replacing it and while you're doing that check the rest of the components - especially the potentiometers, used ones generate a lot of static.
Jan 26, 2010 | Line 6 Variax 700 6 String Modeling Guitar...
Roland fantom -x6 freezing
Shipping something to a repair shop is GUARANTEED to TEMPORARILY fix the problem due to vibration in shipping.
Not sure what you are recording to, but if it is an internal hard drive, that would be the prime suspect. Drives are cheap, replace it and format it!
Nov 28, 2009 | Boss Music
Music Logo
53 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
