Question about Zynga Texas HoldEm Poker
The page isn't redirecting properly Firefox has detected that the server is redirecting the request for this address in a way that will never complete. This problem can sometimes be caused by disabling or refusing to accept cookies.
    New Friend:
11111
Posted on Jun 28, 2013
  • 391 Answers
Hello please go to tools ,internet options and security set to allow cookies set half way or default level also update your flash and java player goodluck to you.
Posted on Mar 26, 2011
How can I downloaad my attachments into microsoft word.
Jackie, This link will show exactly how to enable your cookies in Firefox. Cookies are a technique for your computer to remember pages you visited and setting that are enabled.
To download attachments you can click on Tools>>Downloads.or if you are downloading an image you can right click and select Save as. I would recommend you save to your desktop. The default download location is C:\Users\Steve\Downloads. I hope this helps
Steve
Jan 31, 2015 | Microsoft Computers & Internet
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
I had the same message and problem. Went to Options > Privacy > Remove individual cookies. Select Netflix in the list and Remove Cookies. I reloaded the netflix page and it seemed to correct the problem. I did have to log back into the Netflix site though. everything seems to be working fine now.
Jun 24, 2012 | Gateway Computers & Internet
Firefox has detected that the server is redirecting the request for this address in a way that will never complete. This problem can sometimes be caused by disabling or...
Chances are:
  1. You have not enabled cookies in your browser. Cookies are like your ID card. If you dont give the site your ID card,it would not allow you to next page. See this link on how to enable cookies in your browser
  2. The site might have broken pages,which would not know what to do next. Your browser would ask for the next page,but it would not be present in server.
As with Facebook,the problem no.2 would not be possible. So better clear your history and cookies.
Cheers!!
Aug 09, 2011 | Facebook Social Network
Hi i try to download a torrent-file but get a massage The page isn't redirecting properly Firefox has detected that the server is redirecting the request for this address in a way that will never...
I hope you know that torrent files are illegal and free? People goto jail for sharing torrents its just such a bad thing to do now behave yourself ok b4 you get in trouble. Cheers from Scott and P.S. i love torrents haha its just you cant have em all move on and find another
Oct 17, 2010 | Computers & Internet
Can't load anything now on facebook
You can try a number of different solutions which have worked for some people:
Solution 1.
In your browser, type in the address bar http://www.facebook.com/login (which doesnt exist)
This will take you to a different login page which reads: "The page you requested was not found."
At the top of this page is a login box. Try using this login box to login to facebook.
Solution 2.
Download Firefox 3.5 and used that instead of Internet Explorer.
here is the link for downloading it
http://www.mozilla.com/en-US/firefox/personal.html
Tip: If you are using the Adblock extension with Firefox, and subscribe to an ad list (basically a list of known ads online), it blocks a special site (fbcdn.net)
that Facebook uses to login.
Go to: http://www.facebook.com/login.php (the page you are having trouble logging in) and click on the
Adblock Stop Sign on top of Firefox, and you will see in red a url that includes
fbcdn.net. Right click on that, and add an exception for the entire fbcdn.net domain.
Reload the page. This should fix the problem.
Solution 3.
Use a Proxy Server to connect to Facebook.com
1. Search Proxy in GOOGLE
2. Select Proxy Server
3. Type in facebook.com (in the proxy server webpage)
4. login into facebook account
5. (although all games will work - but Farmville may have problems loading).
Recommended Proxy Server >> http://www.youtubeproxy.ws/
Feb 03, 2010 | Computers & Internet
Can't sign in fackbook?
Solution 1...
Clear your cache and delete all of your cookies in your browser.
Solution 2...
Solution 3...
Tip: Go to: http://www.facebook.com/login.php (the page you are having trouble logging in) and click on the
Solution 4...
5. (although all games will work but Farmville may have problems loading)
recommended Proxy Server >> <<http://www.youtubeproxy.ws/
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
what can happen is that u try a diff browser> like Google chrome> which has no issues with add ons or cookies
Sep 30, 2009 | Mozilla Firefox
Webserver inaccessible from lan
This is default behaviour of port forwarding on ADSL routers.
You need to create a local DNS entry in your machine, which will resolve the domain to the LAN IP of the web server.
Jul 19, 2009 | Computers & Internet
Zynga Texas HoldEm Poker Logo
221 people viewed this question
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
