Question about Hotpoint Washing Machines
Washing machine has died and I dont know how to drain water from drum. HOTPOINT AQUARIUS EXTRA WMS38
  • Hotpoint Master
  • 1,527 Answers
Hello get a bowl or bucket and position the drain hose a low as possible the water should drain out .as for the machine dying do you mean it's total dead if so check the fuse in the plug if ok then check the fuse inside the washer's power supply it's a glass type hope it helps
regards
shaun
Posted on Mar 26, 2011
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Hotpoint Aquarius wms38 1200spin Machine fills with water after wash cycle is finished and it is turned off
If the water is coming in after cycle has finished, then it is 1 of 2 possibilities.
1- A faulty inlet valve, replace it.
2-Water is syphoning back from the sink if it is connected to the sink waste outlet pipe, raise washer outlet hose higher up to solve problem
Nov 30, 2010 | Hotpoint Washing Machines
My hotpoint wmm39 aquarius extra washes but does not spin
you are in an unfortunate delemer. It is either your spin winding thats gone or the control board or timer thats faulty. Normally a technician has spares to test against to prove by process of elimination.Aquick test, pull the pressure switch pipe off the drum assy. and retry spin cycle. Alao take note if all water is drained out of the tub. Let me know
Sep 25, 2009 | Hotpoint WMM39 Front Load Washer
Hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Aug 28, 2009 | Washing Machines
Granddaughter just bought second hand hotpoint aquarius extra wms38 1200 spin .fixed it all up water coming through the ppipes but not in to the machene not filling up or doing anythging any advice please
Soumds like the water inlet valve is not working. You will have to remove the top of the casing and replace thr inlet valve. If the valve is ok then the trouble will be at the programmer. Usually it is the inlet valve.
Jun 09, 2009 | Washing Machines
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing machine won't spin
check the pressure switch the unit wont spin unless it knows all the water is out of the unit
May 28, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
125 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
