We are using windows 7 eternity and the installer is applicable only for windows vista and windows 2003. what should i do?
  • 43 Answers
Right click on executable, select properties,
Then select compatibility tab
Then check "run this program in compatibility mode for"
Then select Windows Vista or 2003
Compatibility works surprising well in Windows 7.
Posted on Mar 26, 2011
I want to install windows vista on my computer AM5640 and at first accepted, but after the first step tells me to wait and the wait is eternal because computer freezes and never moves. I can help solve the...
wondering why you want to install vista in a computer that will totally support windows 7 ultimate. at any rate sounds like you may have a bad install disk. i researched this model and its good build. windows 7 would be better but if your set on vista, call Microsoft and request a replacement disc. as long as you have the original cd and key they will replace it. the disc has the disc id on it.
Jan 28, 2011 | Computers & Internet
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
My new PCCD-ROM F.R.O.G. game will not install on my new Dell desktop computer. Can you help me?
Is the game listed as "for Windows XP" or "for Windows Vista" or "for Windows 7" ?
Is your new Dell desktop running Windows 7?
Are you using the "Program Compatibility Wizard" to install an XP/Vista application
into your Windows 7 system?
Jan 18, 2011 | Computers & Internet
Hi I am Farah, and as I wanted to download java , it came thet" " is not valid win 32 application'. What shoudl I do? Thx
It is possible that you are attempting to install a 64-bit version of Java when you have a 32-bit operating system. Check your operating and confirm this. In Vista you can find this using Start > Control Panel > System. This is similar if you have Windows 7. Here is what it looks like:
If after that you, you follow these instructions from Sun (Java) to locate and install the 32-bit version.
Error: x64.exe not a valid Win32 application This article applies to:
  • Platform(s): Windows 7, Vista, Windows XP, Windows 2000, Windows 2003
  • Browser(s): Internet Explorer, Firefox, Mozilla 1.4+
  • Java version(s): 6.0
SYMPTOMS
While trying to install Java a user gets an error message similar to:
' ... x64.exe not a valid Win32 application'
CAUSE
The error message is a result of trying to install a 64-bit version of Java on a 32-bit operating system.
SOLUTION
User needs to install a 32-bit version of Java software, since a 64-bit version is not compatible with their 32-bit operating system.
Follow these steps to download 32-bit Java
  1. Go to Manual download
  2. Click Windows XP/Vista/2000/2003/2008 Online.
  3. The File Download dialog box appears.
  4. Choose the folder location.
  5. (Save the file to a known location on your computer, for example, to your desktop).
  6. Click Save.
  7. Close all applications including the browser.
  8. Double-click on the saved file icon to start the installation process.
Nov 07, 2010 | Computers & Internet
Tengo una laptop msi vr601 la cual viene de fabrica con windows vista, cambie el windows vista por windows 7 y la camara que trae incorporada no funciona. que debo hacer para que la camara sea compatible...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 23, 2010 | Umax AstraPix PC100 Webcam
How can I install my Quark 7 on my new Windows 7? All I get is 'QuarkXpress 7 requires that your computer is running Windows XP or Windows 2003. Help!
Start the Windows "Program Compatibility Wizard".
Tell it that you want to install a Windows XP application.
Tell it that the software to be installed is on a CD-ROM.
May 29, 2010 | QuarkXPress
Can not install windows 7
if you are doing an upgrade from windows vista to windows 7 check first the version of your vista operating system, for example if you are using windows vista home premium 32 bit then the windows 7 CD that you need is windows 7 home premium 32 bit also, cant mix any versions or types of bit. it should be always the same. try also to download the windows upgrade advisory run it and check for programs and applications that you installed or pre-installed in your computer that cant affect the installation, remove those programs and applications that are not compatible with windows 7. just install those back again after.
if you are doing a clean installation of the windows 7
check first if the system requirements for windows 7 installation is applicable to the specification of your computer. if your system is capable the bqack up your files and go ahead with the installation
i hope this helps
Pls rate my resolution thanks!!
Mar 04, 2010 | Microsoft Office 2007 Basic for PC
I have windows eternity 2009 and i can't install my HP Deskjet driver
When I went looking for Windows 7 Etrenity edition, here is what I found: (My comments are below the line ... )
Windows 7 Eternity ® Edition 2009 x86 / x64 Build 7600 Final ...
10 posts - 4 authors - Last post: Sep 28, 2009 this isn't a genuine Mmcrosoft product. somebody took windows 7 and modified it, there is no such thing as eternity edition. download at ...
www.myxss.com › ... › .: Xclusive Hobbies :.Xclusive Electronix - Cached - Similar ___________________________________________________ As far as drivers go, If the Microsoft Windows 7 driver or other Microsoft OS Editions (Vista, XP, ME, 98 Second etc), nor HP drivers (found at www.hp.com/support) will run your printer, you will have to go to who ever wrote Eternity Edition for your print driver. My guess is this Version of Windows 7 may be real glitzy, but like many glitzy things, will only lead to heart break in the morning when the sun comes up and you remember, you still have to go to work again. Thanks for your interest in FixYa.com and thanks for bringing this oddity to my attention. I have a fairly comprehensive computer lab and I might put it on one of my computers to check it out, for fun.
Feb 13, 2010 | Office Equipment & Supplies
WINDOWS 7 COMPATIBLE?
Yes, just use Windows 7 Update function to install proper drivers automatically. The drivers provided by Brother on CD do not work, though.
Feb 06, 2010 | Brother MFC 420CN All-In-One InkJet...
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
