Question about Haier Washing Machines
Err 7 showing and not spinning, all wires connected to motor?
    Brigadier General:
  • 6,277 Answers
Haier 'err7' decodes as 'motor overheat protection or is damaged' which points to an engineer visit I'm afraid ;-0(
Sorry,
Good luck,
John C
Posted on Mar 26, 2011
  • hario796 Mar 29, 2011
    thanks John C, i managed to get it going again by taking out the motor brushes and cleaning them with sandpaper, only temporary repair but saved a few quid. replacing with new brushes will be next job, once again thanks
Frigidaire oven FSC88B-4 shows "Err F3 " message. What to do?
F3 - Open/shorted sensor (RTD probe) connection.
Check the temperature sensor and the wires and plugs between the sensor and the EOC are good, replace the temperature sensor (RTD probe). If the sensor and wiring are good, the EOC would need to be replaced.
Nov 23, 2016 | Frigidaire Kitchen Ranges
My Bosch Logixx 8 sensitive won't work and shows the code: F:43
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
Apr 03, 2014 | Bosch Logixx WFT 2806 Front Load...
Haier 6kg err7
This problem is quite common on these machines, especially just after the machine has been moved. Err 7 is a motor error. It is usually because the electrical connector has become detatched from the motor. Here is how to fix it.
  • First of all, PLEASE unplug the machine from the wall socket! And switch off the water supply too!
  • Pull the machine out from under the counter, and turn it so that you have access to the back of the machine.
  • Remove the 3 phillips screws that secure the back plate. You are only removing the small plate immediately behind the drum, not the whole back panel!
  • Look through the hole you have just created by removing the panel down towards the bottom of the machine. You will see the motor. Hopefully you will also see a 7 way connector not connected to anything, and a 7-way socket on the motor! (7 way means that it connects 7 different wires!)
  • Plug the connector back on to the motor. Don't worry, it will only go one way round, so you can't get it wrong. If the connector looks like it is connected, give it a little wiggle and a push to make sure it is fully home.
Sep 26, 2013 | Washing Machines
No err appears and not spinning, changed the circuit board still not spinning
Have you checked the motor separately, have you checked the process cycle of machine, if this does proceed then it can be related to mechanical issues of motor or shaft jamming, faulty door switch, faulty connections, faulty water level pressure sensors.
Jan 12, 2013 | Samsung Washing Machines
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
F6 error on Hitachi washing machine Sk 120KJS
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires.
Jul 09, 2012 | Washing Machines
Code f50 is what?
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Motor Circuit
This test checks the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. NOTE: Drain water from tub.
1. See Activation of Manual Diagnostic Test Mode, and check the motor and electrical connections by performing the Agitate and Spin tests under Manual: Motor. The following steps assumes that this stepfailed.
2. Unplug washer or disconnect power.
3. Check to see if basket will turn freely. If basket turns freely, go to step 4. If basket does not turn freely, determine what is causing the mechanical
friction or lock up.
4. Remove the console to access the machine/ motor control assembly. See Accessing& Removing the Electronic Assemblies.
5. Visually check that the P5 and P10 connectors are inserted all the way into the machine/motor control. If visual checks pass, go to step 6.
If visual checks fail, reconnect P5 and P10 and repeat step 1.
6. With an ohmmeter, check for 16 ohms resistance at the P5 connector between pins P5-1 and P5-2, and also between pins P5-1 and P5-3. Also measure the resistance at the P10 connector between pins P10-1 and P10-7 and verify that the resistance is within the range shown in the wiring diagram on page 7-1.
If the resistance is correct, go to step 11. If the P5 connector resistance is much higher than 16 ohms, or the P10 connector resistance is out of range, go to
step 7.
7. Tilt machine forward to access the bottom of the machine and the drive motor area. See Figure 1 on page 6-13. Remove the motor bolt, then the motor cover to access the motor connections. See Figure 2 on page 6-13.
8. Visually check the mounting bracket and electrical connections to the motor and rotor position sensor board. If visual check passes, go to step 9.
If visual check fails, reconnect the electrical connections, reassemble stator and motor cover and repeat step 1.
9. With an ohmmeter, check for continuity between all pins on the P10 machine/motor control connector and the motor rotor position sensor (RPS) connector. See Figures 2 and 4, pages 6-13 and 6-16. If there is continuity, go to step 11. If there is no continuity, replace the lower machine harness.
10. With an ohmmeter, check for continuity between all pins on the P5 machine/motor control connector and the drive motor connector. If there is continuity, replace the drive motor. If there is no continuity, replace the lower machine harness.
11. The drive motor and lower harness are good. Replace the motor RPS board and perform the Diagnostics test in step 1 to verify repair.
12. If the Diagnostics motor test in step 1 failed, then the machine/motor control has failed: Unplug the washer or disconnect power. Replace the machine/motor control assembly. Perform the Motor Diagnostics in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
3 year old Whirlpool Duet - F07 error showing up 98% of the time on high spin; 70% of time on medium & low spin. Checked conections between MCU & CCU. Should I buy a new MCU or a new washer?
No do the following:
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
If the wiring is definitely OK and the drive motor is OK then the MCU is most likely to be the culprit.
Dec 30, 2009 | Whirlpool GHW9100L Front Load Washer
Will not extract on spin cycle
After oheming motor control board as stated in the service manual. Tracing the 6 pin lead wires from the control board to the motor plug. I found that one of the pin on motor plug was not making proper connection. I used a screw driver to pry the pin open so it made a better connection. Tried the washer and so far it has been working 7 washes.
Mar 27, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
308 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
