Wireless lan card set up - Computers & Internet
  • 84 Answers
If you have already installed the lan card , make sure to run the software that is bundled with the wireless card. then it has a set-up wizard that will go on , step by step. hope this help you out
Posted on Aug 04, 2008
Need isatap driver for vista
im assuming its a laptop computer
Turn the laptop over and remove the battery.
Remove the screws that are used to secure the memory/wireless LAN minicard cover with a Phillips-head screwdriver. Lift the edge of the cover to remove it.
Disconnect the antenna cables from the wireless LAN minicard with the needle-nosed pliers.
Locate the screws that are used to secure the wireless LAN minicard to the motherboard and remove them with the Phillips-head screwdriver.
Pull the wireless LAN minicard out by grabbing the card by the edges.
Reinsert the wireless LAN minicard and push down on the card to set it in place.
Tighten the screws to secure the card to the motherboard.
Replace the antenna cables with the needle-nosed pliers.
Replace the memory/wireless LAN minicard cover and secure it with the screws.
Replace the battery and then turn on the laptop. Windows Vista will load and reinstall the drivers for the ISATAP adapter.
hope this helps
Sep 22, 2012 | Asrock K8Upgrade-VM800 Motherboard
I have a Dynex 802.11 Wireless G laptop Card. I was not reading my signal from th router. A netgear tech told me to uninstall and reinstall the card. My system is not founding the new hardware to... may help you.
It may be your Lan settings not configured.To check this go to tools in int explorer and click on connections/LAN/SETTINGS.Make sure the box,"Automatically detect settings,"is ticked.
Sep 12, 2010 | Dynex 802.11g Wireless-G Laptop Card
2.4GHz Wireless Lan And 5 GHz Wireless LAN
this is usually caused by your router and your wireless network card are not compatible... you need to purchase as well cisco wireless network card adn tehn when you press your wireless security on the router, it will automatically apply all security protocol to the connection.
if you do not want to purchase new card, you always can setup these devices manually,
connect to the router via rj45 cable, establish what protocol, security and transmission method/frequency you will be using, write that down, disconnect the cable, enter your wireless network card settings and apply same settings to your network card, this should solve the problem.
as you did not stated what operating system you are using and what card is in your computer, this is unfortunately best advice which can be given.
how to set up your router, you have downloadable pdf file on linksys site.
Jul 28, 2010 | Linksys Wireless-G WRT54G Router
Epson sx510w prints using a cable but can't get it to print wireless
The specs for your model Epson allows you to connect the you network by wireless and by LAN cable.
The specs are as follows :-
Wi-Fi Wireless LAN IEEE 802.11b/g – compatible with 802.11n*
*Transmission rate will be limited to 802.11g and will operate in the 2.4 GHz frequency band
Ethernet Wired LAN IEEE 802.3 (100BASE-TX, 10BASE-T)
Other PictBridge
Wireless security
WEP – 64bit
WEP – 128bit
WPA – PSK (TKIP) – compliant with WPA2
WPA – PSK (AES) – compliant with WPA2
To connect the printer by a LAN cable you need to configure the Epson for an IP address that suits your network configuration and connect the LAN cable to your wireless router/hub.
The reason why you cannot print using wireless is because the wireless configuration in the Epson is not setup with the router's wireless configuration ie. SSID WPA encryption etc.
For instructions of setting up a LAN network printer, please click on this link and follow my instructions :-
For instructions on setting up a wireless printer, the Epson wireless settings need to be configured with the router's wireless settings. Go into your router's wireless and note the SSID, and encryption settings etc and configure the Epson's wireless settings with the router's wireless settings. This will allow the Epson to connect to the wireless router. Please click on this link for instructions to secure your wireless network, configure the wireless router (if you have not already do so) and configure the wireless card in the computers and wireless printer (the instructions for configuring the wireless card in the printer is the same as for the wireless card in the computers via the printer's menu screen).
Feb 07, 2010 | Epson Office Equipment & Supplies
The wireless internet connection wont work. we previously had a wireless connection and now it wont register. we lost the connection completely and it doesnt show up on the list of internet connections....
Try turning off the router for 30 secs, then power it up again.
Then try connecting a LAN cable from the computer to the router and see if you can connect to the Internet.
If you can connect to the Internet then -
With the LAN cable open a browser and type in the configuration URL and check the Wireless settings, then check and/or the wireless card settings (it should have the router's SSID and encryption settings etc.)
Also install the latest wireless card driver.
Then test the wireless and Internet connection. If this doesn't work -
Next connect the computer with a LAN cable to the cable or DSL modem to see if you can connect to the Internet.
If you cannot get an Internet connection with the LAN cable, contact your ISP and get them to test the connection to your modem.
If the modem and Internet is OK and you still cannot get a wireless connection then the problem could be a faulty wireless router.
Dec 25, 2009 | Dell TrueMobile 2300 Wireless Router...
Cannot connect to internet via wireless hub to laptop
When you power up the wireless router and the LEDs are ON then the router appears to be OK and this also applies to the DSL or cable modem.
To check if the modem is configured to your ISP settings and connects to the Internet, connect the modem with a LAN cable to your laptop and check if you can connect to the Internet.
Next, the wireless router needs the wireless settings configured and then configure the wireless card in the laptop with these settings so it can communicate with the wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 14, 2009 | Computers & Internet
I have netgear lan card but it is not workin in
you posted in Wireless Access Points. Either way, you can go to the Netgear web site and see if you have Vista drivers for your particular LAN card. try click on support and input your card part number. Note that this number ought to end in 11 as in wg311, 511, etc. I searched for LAN CARD VISTA DRIVERS and got a whole set of Vista notes for the various cards. Carl
Jun 16, 2009 | NetGear (WG602MES) 802.11g/b Wireless...
Wireless adapter
check the ettings on the router have not been altered. the chance of 2 wireless cards failing in the same time, on different pcs is very small, more likely the settings that allow connection in the router, the item common to both, have been changed, reinstalling the router has no effect on user settings,
WEP, encryption, MAC controls are all possible suspects, if there has been any change
lock down the router,
many wireless networks are unsecured at the router so that any person driving past can access your router and alter it, default security settings should be changed the day you turn it on
Jun 28, 2008 | Computers & Internet
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
