Question about Samsung S3650 Corby / S3650 Genio Touch Cell Phone
I have problem in accessing internet on my dolphin browser it shows dns failure so whats the basic solution that i can use reply soon.....
    Problem Solver:
  • 5 Answers
You could always try reverting to a static ip, or if the phone allows it, just change the dns,
A reliable one for me is on opendns and it is
208.67.222.222 and the secondary is 208.67.200.200
Posted on Mar 26, 2011
Dolphin Browser for PC Available?
Dolphin is not officially available for Windows. However,with little trick, you can install it on your Windows PC. Follow this step by step tutorial:
https://kemalwindows.bandcamp.com/album/dolphin-browser-for-pc
Oct 23, 2017 | Dolphin Computers & Internet
How To Fix Google Chrome Error 105?
Error 105 indicates that Chrome can't find a DNS server.
Without a DNS server, a browser can't find a web page using a domain name (such as google.com) and therefore cannot surf the web.
If you have another browser, such as Edge, Internet Explorer, or Firefox and they cannot reach google.com either, then you are either not connected to a network with internet access or your browser has been hijacked.
If you are on a windows computer, use Windows+R or click in the Run box on your start menu and type cmd to pull up a command window. type >ping google.com and hit enter... if it pings the address successfully, then you have DNS and your browser has been clobbered.
Otherwise try connecting to another network, contact your network administrator, or examine your TCP/IP settings for your current network adapter and set your Preferred DNS server to 8.8.8.8 (google's DNS server) and the Alternate DNS to 4.4.4.4 (also google). This should give you access to the whole internet via domain names.
Sep 21, 2017 | Google Computers & Internet
When open internet it showing DNS error what to do?
By "it" may I assume you mean the web browser?
DNS errors are usually caused by one of two things:
1. You are not connected to the Internet, or
2. You're trying to access a site with no DNS entry (e.g. there might be a small error in the URL or site is no longer registered)
Sep 28, 2012 | HTC P3400 Touchscreen Windows Mobile Smart...
I cannot access internet on my samsung monte...it shows DNS failed
You need to go to the settings, network settings , browser profiles , open and go down to advance settings and you will see DNS server 1 and 2 , you will need to get the DNS settings from your service provider and insert them in it.
May 02, 2011 | Samsung S5620 Cell Phone
Internet connection problems
Troubleshooting Internet Connection Problems The purpose of this section is to give general tips
on troubleshooting your Internet Connection
While there are many possible configurations, I'll try and cover the most common ones.
Making Sure You Have Correct IP Information
Basic PING Tests
Browser Configuration
Making Sure You Have Correct IP Information 1. Make sure you have the correct IP scheme for your network. This would include the:
  • IP Address
  • Subnet Mask
  • Default Gateway
  • DNS Servers
2. There are a few ways you can see what IP addresses are being assigned.
But generally for:Win9x - Start / Run / command
Windows2000/XP/Vista - Start / Run / cmd
The run IPCONFIG /ALL. A sample where a router is used is in the following graphic.
ipconfig.jpg 3. IP Address:
If you have a router, common examples would be:
192.168.0.x, 192.168.1.x or 10.0.0.xIf you are directly connect to your DSL or Cable Modem, you should have an IP address that would correspond to something from your ISP.
What you don't want to have is something like 169.254.x.x. This means you are not getting and IP address assigned and needs to be resolved first.
4. Subnet Mask:
Also make sure you have the correct Subnet Mask. Most commonly this would be 255.255.255.0 5. Default Gateway:
Make sure you have the correct Default Gateway IP address.
With a router, this is typically the IP address of your router. 6. DNS Servers:
Make sure you have the correct DNS Servers. Sometimes this is the IP address of your router, so it would be the same as the Gateway IP.
Sometimes (as in this example), it is the actual DNS servers used by the ISP.
7. Possible causes for not getting an IP address assigned are:1. Defective cable, network card or port on the router. Make sure you are using all known working components.
2. Your router is not configured for DHCP (which would automatically be assigning IP addresses).
But you need to have this correct before proceeding.
Basic PING Tests 1. This and can be done from that same command prompt you used to run IPCONFIG 2. Try pinging the router's IP addresse.g. ping 192.168.1.1
If you get a reply, then your connection to the router is working.
If you don't get a reply, then you need to double check your network card, cable, port on the router. You might also see if any other computers on the network can do the same.
3. Try pinging an external site by IP address e.g. ping 4.2.2.1
If you get a reply, then you have a connection to the Internet.
If you don't get a reply, there are several things you can try:
1. Double check that the router is connecting to the Internet. Typically you can access the router through your web browser and check it's status.
2. Take the power off your DSL/Cable modem and Router. Plug the modem back in a wait a minute or so. Plug the router back in and wait a minute or so. Then restart your computer.
3. Winsock Fix - It is possible that the Winsock Registry entries have gotten corrupted. This is getting to be a more common problem. See WINSOCK FIX for clean ones you can download
4. Try pinging an external site by Namee.g. ping www.yahoo.com
If you get a reply, then you have a connection to the Internet and DNS is working
1. Double check your DNS entries
2. You many need to use the same DNS IP address that your ISP or Router is using.
3. On rare occasions your ISP has problems with their DNS servers. But that is rare in comparison to misconfigured computers.
If your PING tests work but you are having problems browsing sites on the Internet 1. If you could ping external sites by both IP address and Name, but cannot browse the web, likely your web browser is misconfigured. 2. Double check that you don't have an incorrect or not needed Proxy server assigned.For the Internet Explorer - Tools / Internet Options / Connections tab / LAN settings button. Uncheck both Automatically detect settings and Use a proxy server for your LAN.
Mar 28, 2010 | HP Pavilion dv9720us Notebook
Belkin adapter f6d4050 not connecting to internet
| |the belkin adapter connects to the airport express router | | sounds like the adapter driver has installed all OK if you have connection to the router. Therefore something is blocking access on your PC - the most common thing is a firewall. to test if you do have access to the internet can you do the following:-------start>run{vista/7 search box}>CMD>ping google.com ----- see if you get a reply message sent 4 times - if you do then you do have access to internet - if you do not get a reply do this ping 209.191.93.53 ------ if you get a reply from this number BUT not from the name then its a DNS issue. ------------ assuming that you get a reply from both , then I suspect its a firewall blocking, disable the firewall, now firewalls such as Norton, Mcafee etc can cause issues even if you think you have removed them in the past , or a subscription has expired. to remove these firewalls i would suggest you use a removal tool which is available at most of the manufacturers website - if you reply with a comment on what you have I can post the link now if its a dns issue try the following ---------- start>run{vista/7 search box}>CMD>ipconfig /dnsflush -------- if that does not work - then you could try a public DNS like google public DNS here http://code.google.com/speed/public-dns/ the link also shows you how to configure your PC - if that works then post a comment back and we can see if we can get it working on the correct dns servers from your isp
Mar 15, 2010 | Computers & Internet
Internet explorer not working
Check whether your internet connection is working properly or not. To check this ping to your DNS Server of your internet service provider. If you get a reply from the DNS Server then the problem is with your browser, if so then install another browser like Mozilla Firefox or Google Chrome. If you dont get a reply from DNS server contact your ISP and resolve the Issue with them.
Oct 19, 2009 | ASUS Eee 4G Notebook
Cabel to router
More details would be helpful.
Is your internet cable, dsl (telephone) or something else?
What is the make and model of your router?
Are you trying to connect wired or wireless?
What operating system are you using.
Assuming that this is a wired router with DHCP turned on and your network adapter is configured to obtain IP and DNS addresses automatically. Turn off or unplug everything. Connect the cat5 cable from the cable or dsl modem to the WAN or INTERNET port on the router. Connect a cat5 cable from any of the other ports to you computer. Now turn the cable/dsl modem on and wait 60 secs, then turn the router on and wait 60 seconds, finally turn your computer on.
BASIC TROUBLESHOOTING (assumes XP with at least SP2)
Open a Command window - START - RUN and type in cmd, click OK
A Black windows with white text opens.
type "ipconfig /all" without the quotes and press enter
this should display your ip address, the default gateway and dns servers
type ping followed by your default gateway address example: ping 192.168.0.1
if you get a reply this means that he communication between your computer and the router is ok
next ping 74.125.19.147
This is the ip address for google, if you get a reply you do have access to the internet
try your browser, if it shows page cannot be displayed, enter this in the address bar -
http:\74.125.19.147
If you see a google page open up it means you have a dns problem, go back to the command window and type "ipconfig /flushdns"
If you cannot even ping your gateway,open the command windows and type "netsh winsock reset catalog" then reboot
More details in your questions means more specific answers :)
Sep 28, 2008 | NetGear WGT624 Wireless Router
Router connecting to Linksys USB adapter
to confirm if your Network adapter's assigned IP, subnet, Gateway & DNS
  • Start > Run > cmd
  • at cmd prompt type: ipconfig /all
  • look at the parameters given to your Network Device that is connected to the router (IP, Subnet, Gateway & DNS Servers.
  • Verify those addresses if they are reachable by pingging. Check your IP, Gateway, then check for the DNS Addresses. Type cmd prompt: ping ip_address << do not omit the periods between the numbers.
  • See if there are replies from those addresses. if you get Request timed out, tell us here which part you get one. if you can receive a reply from those addresses (gateway & DNS Servers) definitely you are already connected to the internet. Just check your Browser's connection setting.
Jul 06, 2008 | Linksys Computers & Internet
Psp dns failure
How is the machine connected to the Internet? Modem, cable or ADSL? Or are you using it at work through a company network?
Jan 06, 2008 | IBM ThinkPad T30 2366 Notebook
Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
116 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
