Question about Vulcan Heating & Cooling
I have a pyrox vulcan wall furnace, model 4720006. when I turn it on, nothing happens. The F1 isn't showing on the screen as malfunctioning but it seems the pilot light doesn't start up when I press on. Have tried turning on and off but still nothing works. (it's getting a bit chilly.....)
    Master:
  • 346 Answers
Hello Chilly - First I'd like to know if this is a new unit or one that has been working until now.
If it had previously working are these the steps you're going through to start it?
START-UP SEQUENCE 1. Press the ON / OFF button. 2. Raise the temperature to HIGH so that the heater calls for heat 3. Within 10 seconds the gas valve will open and the sparker will function. Ignition will commence on a low gas rate and move to high fire after 3- 5 seconds (if high is selected on the control) 4. Within 5 seconds the flame sensor will prove the flame. 5. The fan will not operate until the fan thermostat switch has sensed temperature rise. This may take 2 or 3 minutes. 6. The fan will then start on a low fan speed and after 3 - 5 seconds move to high speed (if High is selected on the control)
If that is or is not what you have been doing let me know and we'll go from there.
Regards,
Mikeywaf
Posted on Mar 26, 2011
Does Vulcan Pyrox gas wall furnace have a filter? It seems to cycle on and off too often and the gas seems too high. Also it makes a bang when reigniting. How can I turn the gas down inside it?
get it serviced by a licenced gas fitter / plumber. Should be serviced every two years. Don't risk your life via carbon Monoxide poisoning get a licenced gas fitter /plumber to assess the unit.
Jul 12, 2015 | Vulcan Heating & Cooling
Trying to locate replacement parts for my gas wall heater
http://www.enviro-friendly.com/bonaire-gas-wall-furnaces.shtml
Bonaire pyrox is the old Vulcan company
Standard Appliance Parts Sacramento California can get you anything you need as well.
Apr 05, 2015 | Vulcan Heating & Cooling
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Sep 01, 2011 | Heating & Cooling
Pyrox Vulcan gas wall furnace.
my pyrox wall furnace has a digital pad it turns off & on but i cant turn the heat or fan uo or down its 4 weeks old
Jun 13, 2009 | Heating & Cooling
Error f1 3
What did you find out about this code? did you contact Pyrox? ask them the code meaning. if it is a need for a tech then thats the way to go they should be able to advise you.
Jun 09, 2009 | Carrier 36KCARMS Air Conditioner
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Vulcan gas wall furnace keeps turning off, and has err f1 on the control panel. Any suggestions? It is Sunday afternoon and about 8 degrees!
No idea what the problem is but - We have a manual vulcan gas wall furnace about 3yrs old and it has always been switching off since installed which is a real bummer on cold days. We had it checked out whilst under warranty but the technician did not fix the problem. Im not sure if it has anything to do with the gas supply but seems more of a product fault. Lucky weve got a combustion stove as well!
Jul 27, 2008 | Heating & Cooling
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
411 people viewed this question
Top Vulcan Heating & Cooling Experts
Paul Carew
Oloyede Monsuru
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Heating and Cooling Expert? Answer questions, earn points and help others
