Network always failed..slow browsing..sometimes no signal
  • 43 Answers
This happens with some commercial router brands over time. I have had Dlink, Netgear, Linksys, TrendNet all succumb to this problem. Usually about every three years or so I start to notice lower and lower QOS. If your router is that age, I suggest replacing.
Posted on Mar 26, 2011
When sending the ethernet signal from my modem to my GreyFox F7810 home system through the wall, I sometimes get the 100mbps download that I should be getting but other times I only get 10mbps, how ca
how are you checking this speed.
the speed you appear to be quoting at the computer is the speed the lan network socket is running at. it's probably rated at 10/100
some peripherals only have a 10M interface hence you only get a 10M reading and sometimes will slow the whole network down.
not sure what you mean when you send your network 'through the wall'. if that's using a powerline adapter, the connection between them often only runs at 10M. I've got 500m powerlines and they're often down to 10M, sometimes 100M but not very often.
Dec 20, 2014 | Computers & Internet
Tip
Solution on a slow Internet connections Problem  The major  causes for a slow...
The major  causes for a slow Internet connections. A poor-performing connection can be caused by broadband router configuration issues, wireless interference, or any of several other technical issues with your home network. Follow these steps to diagnose slow Internet connections.
 1. Broadband Router Settings
As the centerpiece of a network, a broadband router can be responsible for slow Internet connections if configured improperly. For example, the MTU setting of your router will lead to performance issues if set too high or too low. Ensure your router's settings are all consistent with the manufacturer's and your Internet Service Provider (ISP) recommendations. Carefully record any changes you make to your router's configuration so that you can undo them later if necessary.
 2. Wireless Signal Interference
Wi-Fi and other types of wireless connections may perform poorly due to signal interference, which requires computers to continually resend messages to overcome signal issues. Household appliances and even your neighbors' wireless networks can interfere with your computers. To avoid slow Internet connections due to signal interference, reposition your router for better performance and change your Wi-Fi channel number.
 3. Internet Worms
An Internet worm is a malicious software program that spreads through computer networks. If any of your computers are infected by an Internet worm, they may begin spontaneously generating network traffic without your knowledge, causing your Internet connection to appear slow. Run antivirus software regularly to diagnose and remove these worms from your computers.
 4. Running Background Applications
Some software applications you install on a computer run in the background, quietly consuming network resources. Unlike worms, these are programs designed to do useful work. Peer to peer (P2P) programs in particular can heavily utilize your network and cause connections to appear slow. It's easy to forget these applications are running. Always check computers for any programs running in the background when troubleshooting a slow network.
 5. Faulty Network Equipment
When routers, modems or cables fail, they typically won't support connections. Certain technical glitches in network equipment, however, adversely affect performance even though connections are maintained. To troubleshoot potentially faulty equipment, temporarily re-arrange and re-configure your gear while experimenting with different configurations. Try bypassing the router, swapping cables and changing network adapters to isolate the slow performance to a specific component of the system.
 6. Service Provider Issues
Internet speed ultimately depends on the service provider. Your ISP may change their network's configuration, or suffer technical difficulties, that inadvertently cause your Internet connection to run slow. ISPs may also intentionally install filters or controls on the network that can lower your performance. Don't hesitate to contact your service provider if you suspect they are responsible for a slow Internet connection.
 www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Nokiac1 mobile modem internet very slow how to increse speed in pc
Sounds like you are using a cellular modem. Internet through the cell phone network is usually always going to be slow, nothing can change that other than making sure you have a device that supports 4g and you have 4g signal. Anything else is going to be slow and the lower the signal the slower it will be.
Apr 11, 2014 | Arris SURFboard SB4100 Modem
The internet is very slow, and sometimes does not work
the phone will not browse if the settings are wrong.. therefore it is possible that its a function of your network provider....
if problem persist see the representative of your network provider for assistance
Feb 13, 2011 | HTC Legend Cell Phone
Failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
It connects and but time with very slow and show
It's always difficult to troubleshoot wireless because the signal can be effected by so many different variables. Easiest thing would be to connect another wireless device. If that works OK then it's your computer or wireless adapter. If that drops out too then it's your wireless router. When we find out what's at fault we can find a more detailed solution if you' be kind enough to post back.
Dec 12, 2009 | Computers & Internet
Unable to connect to internet through Wi Fi on Nokia E65
You need to "authenticate" the wireless meaning you need the password to the web signal. Your phone may have an internal software issue in which it prevents you from connecting to the internet. Contact your phone company to trouble shoot it or get a replacement phone.
Mar 18, 2009 | Nokia e65 Cellular Phone
Orange networking on a sonny ericsson w595
Try selecting 2G only if you're not too bothered about video calling or mobile browsing. This tends to give a much better signal stability. Also preserves battery life too. I've found in the past with my K800i, if the 3G signal was weak or patchy, it didn't always switch over to 2G mode, meaning that more often than not calls were not able to be received nor made.
Oct 15, 2008 | Computers & Internet
Cannot browse internet to samsung e250
thrw your phone in the wall and try again :))
Jun 30, 2008 | Cell Phones
Network browsing is very slow in our workgroup
try giving all the nodes static IPs Add. OR check for Worms on the nodes coz they navigate through network , choking the switch
Dec 14, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
