Question about Xerox WorkCentre M-24 Color Copier
Sharp line on print, even all new drumbs - Xerox WorkCentre M-24 Color Copier
    President:
  • 2,072 Answers
Is it on prints and copies? Or just prints or just copies.
There are 4 likely causes if the line is on both prints and copies. 1 The transfer belt has a scratch on it. 2, The Transfer belt cleaner, called the IBT cleaner is worn, or the fuser has a cut in one of the rolls. Also the 2nd BTR roll located on the left hand door may be damaged.
If the problem is only with copies, then the scanner glasses or mirrors are dirty.
Posted on Mar 29, 2011
How do I clean the printhead on Sharp 3501N?
Hi, Go into printer properties. Click on clean printer chartridge.
When you do this it will run automatically. Do this several times to make the color come out clean. Good luck.
Apr 01, 2014 | Sharp MX-3501N All-In-One Printer
Sharp maintenence code ta
Follow the instructions below. A few quick changes in the port setting will allow you to print again, even though your machine needs maintenance.
Sharp Printer Offline Solution
Jan 23, 2014 | Sharp Mx-B402sc mx-B402sc
Sharp MX-2300N - can only print on computer restart
You will have to contact Sharp's service department.
Apr 30, 2012 | Sharp MX-2300N Color Copier
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Canon i865 - black print is blurred/fuzzy on every 3rd line. Have done clean, deep clean, changed both 3 and 6 cartridges. No problems until recently. Beautiful full colour photographs clear and sharp,...
Your printhead has burned out nozzles, the black is the most used and first to go. It switches nozzles during printing for even wear, that's why every few lines you get bad spots.You need a new printhead.
Aug 07, 2009 | Office Equipment & Supplies
On sharp AR-163 I have white lines(text mising)from top to bottom ? It happens even when you print only
if you make a copy and the copy is ok but the print copy is bad . this sounds like you might have the wrong printer driver set up.
all sharp al-ar small copiers u must have the exact driver for coper model you can get them at sharpusa.com under personal copiers
Mar 11, 2009 | Sharp AR 163 Copier
Errors??
Sounds like the printwheels are out of time. Sorta of major repairs. gears on side of printer have to be lined up in proper areas. there are small black arrows on the gears. Best bet is look at a working machine and try to line up. Machine may not be worth the time unless you jsut want to try it. Sharp uses the same printers in many different models.
Jun 21, 2008 | Sharp EL-1611P Calculator
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Drum issue
Try another cyan toner cartridge, If you are using compatiables it my be defective.
Jan 30, 2008 | Canon imageRUNNER C3220 Color Copier
Xerox WorkCentre M-24 Color Copier Logo
90 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
