Question about Uniden GRANT LT 2-Way Radio
Uniden grant lt transmit and receives normally but when i key up on AM the AM power regulator gets hot quick i changed out the driver and final and replaced the regulator still does the same thing and it seems that the power output is a little low also modulation
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 98 Answers
Sounds like a "short" if it affects modulation + power. Try to inspect board with magnifier for solder bridges, and bad resistors. Change a few resistors near back with new ones. take out slugs near back finals like L10 or L20's not sure if its same as Uniden Pc68xl. but try that. I found turning L19 up to top gave great Modulation. clip D9, Sread coils 1/16 inch in back. Try to get lower carrier. Carrier does not mean anything much. Modulation is what you need. With less Carrier it may cool down that chip. It may be too wound out.
Posted on Mar 31, 2011
Why does the uniden grant go into transmit mode when turned on
if this happens without a mic attached, it is common for the tx/rx switching transistor to fail
Aug 16, 2014 | Radio Communications
I I have an old Uniden PC 55 CB radio that I picked up at a junk store. After some tinkering, it seems to receive just fine (a little scratchy) but it won't transmit. A friend replaced the connector on the...
The final amplifier circuit goes out on these often. It controls transmit power. They transmit, they light up, they emit about .25 watts or less. IMHO, you are done. They simply are not worth anything and there are no parts available for that repair.
May 28, 2017 | Uniden Radio Communications
Uniden grannt xl will not transmit
I can tell you that mic wires can simulate that problem when they accidently touch or ground out. Sometimes a ground is loose or capacitor leaks. Check standing wave ratio. SWR 1.5 or less prefer 1.2 or 1.3 read. Antenna cables replacement and new ends. Dirt in mic switch. Mine did this with a power mod capacitor
near final(without proper discharge 100 ohm resistor). I turned back power to 1 1/2 watts to 4 swing a Tx tuning slug *redpaint on it. I let it talk on low key an when i speak it jumps to 4 or 5 watts on meter. When a mod has been done some people don't know that capacitors discharge and it will leak back current. Thats why on a Cobra/Uniden company radio the instruction properly call for a 100 ohm resistor to be placed in parallel with Capacitor near final on bottom of circuit w/ capacitor on top spkr side(i call it top its on spkr side bottom when radio is upright (super mod kit). Or replace jumper J1 to factory deadkey of 4 watts and see no swing in talk except to 4.5 watt slightly(factory tune)
Jul 22, 2013 | Uniden Radio Communications
No transmit on my uniden washington
Would it help to refer this problem directly to Uniden?
Mar 07, 2013 | Radio Communications
I have a galaxy 44v that recieves keys up but know watts come out i have put new finals new voltage regulators b754 and the one in front of it changed the 300v redish " dog tic" thats what we...
  • The Galaxy 44 has 1 final and 1 voltage regulator not "finals." I doubt it is putting nothing out although it may look like it on a watt meter. Check VR16 (low power adjustment for the amp) and VR 13 (High power adjustment) for the amp in the radio. That radio has a variable power so make sure the pots were not turned out of whack. Check VR 14 as well. this is your AMC modulation pot adjustment.
  • Test the driver as well as the pre-driver. Check your microphone to make sure the wiring is good and the PTT is functioning.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 07, 2011 | Galaxy Radios DX-44V 40-Channels Base CB...
I have a uniden Grant like to wire up a 4 wire D104 the mic has white black red shield
Wiring 1 4 pin D104 mic to a Uniden Grant CB is as follows -
  • Pin 1 - Shield - Shield
  • Pin 2 - Audio - White
  • Pin 3 - Transmit - Red
  • Pin 4 - Receive - Black
Regards, Tony
May 05, 2011 | Uniden GRANTLT 40-Channels Base CB Radio
Uniden president grant stops transmitting wait 1 or2 minutes and it will transmit for a little bit then does it again never lose my recieve thank you for your intrest
i cant afford 20 dollars to fix that radio your add said free i am laid off the old grant will have to waite i am not a teck have no idea what is wrong thank you for your time sorry to bother you ihave a good ole cobra29 that i talk on now grandadmac50@ yahoo.comm
Jan 30, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Uniden Grant XL No Transmit
on the back of the radio you will see a small circuit board with a transistor on it this is your am regulator.check to see if that has gone bad
Jan 27, 2009 | Radio Communications
Uniden GRANT LT 2-Way Radio Logo
101 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
