Question about Electrical Supplies
I have a three way plug that needs wiring. the cable has two wires a brown and a blue. with the earth wire at bottom is the blue wire on the left side or the right side
  • 40 Answers
Earth on the bottom, the neutral (blue) will be on your right. The live (brown) will be on your left.
NB: Its not a big issue though if you swap the sides as the current that you are dealing with is alternating. If by mistake you swap the wires, you appliance will still work.
Posted on Mar 26, 2011
The towing plug has been cut off. Trying to wire
in most red is stop ,yellow is left signal , green is right signal, brown or black is parking lights ,white is ground use a test light to comfirm what your doing , like turn left blinker on test wire and tempararly connect and so on ,be sure to hook up ground first. if you need more help just send a message in comment section at bottom
Oct 08, 2014 | Cars & Trucks
Essick air compressor wiring diagram
telepathy do not work that hot as in hollywood movies...
you need to provide a model or at least if this is three phase or single phase...
single phase is easy, you have cord with three wires, earth, active and neutral.
you need to open connection box on your compressor and you will find three wires there terminating in junction box, earth connect to earth (usually green or green with yellow stripes), then you have your neutral (usually brown or black) and active (usually blue or red), connect them, do not put cover on yet, plug cable into the power point and switch on/off power. check if motor is rotating in correct direction, if fuses are not blown... if motor is rotating in wrong direction - switch power wire with neutral wire, it just meant that you wired it in reverse...
do not need diagram for that...
do not forget to give some points...
Dec 30, 2013 | Park Tool Inf1 - Shop Inflator For Use...
I just purchased a C8FB compound miter saw , it had no switch, i have new switch but no idea where the wires go?
Hi, all a switch does is break the conection from supply to appliance
in most of these saws it can be pretty simple, assuming it is not
three phase you will have six wires 2 brown 2 blue and 2 yell/green
he switchitself should have six conectors , these can be marked
(L) live brown (N) neutral blue and (E) earth yell/green.and may say
load or supply now , the supply is the cable going into the machine
from the plug , and the other cable is the load....T.C.
Mar 19, 2013 | Saws
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Wire coming into electric shower has Red (Live) Black (Neutrl) Yellow green (earth)Wire in the shower unit is BLUE & BROWN and the Earth which one of the BLUE and the BROWN wires is the live and the...
hello martin, you obviously have one three fase cable for swiching in power. If we consider european standards the blue is neutral ; 2 blacks and brown are phases = live (now the red one here is bit more than usual in european cables) becouse they have only 5 wires and you mention 6.
  • you must inspect the ends with ohm meter and realise the right way to swich it.
  • you might have one relay inside your device and you might need to measure wire colors after relay, so be pacient and go step by step.
Mar 02, 2011 | Home
Hot and neutral wiring not color-coded on plug, three prong. Green is color coded.
1,brown/red is live to right.2,blue/black left.3 green is top of plug its earth .good luck.adrian,,
Oct 15, 2010 | Bosch Evolution 500 SHE45M05UC Stainless...
Plug wiring
When wiring a new plug for which voltage input?
The cutter has a white wire, a black wire, and a green one - white is the neutral line, black is the hot line, green is ground.
You can see this in section 4-9 of the owners manual, if you don't have a manual you can go to www.millerwelds.com and get a PDF file of the manual.
Rank this answer please,
Carl
Nov 26, 2008 | Miller Welding Tools
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
