Hi, i want to ask what i need to do for replacing the hinges by my self step by step. thank alot Erez
  • 32,281 Answers
These WEB sites gives instruction on replacing honges on laptops.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Posted on Mar 26, 2011
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
The right and left - hand hinges of my Asus notebook got damaged. Where can I have them repaired? Only those parts got broken a little bit, just like semi-fructures. Thanks.
Hi, Just go to ur nearest computer shop and ask them to replace that hinge! the hinge becoming stuck and only solution would be to replace it! The crack can be repaired and repainted if there is no available parts in the market. Ur concern should be the hinges, replace it before it breaks the whole hinge holder!
Jun 14, 2011 | ASUS Computers & Internet
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
Aug 03, 2010 | Sanyo SR-4910M Compact Refrigerator
I need to replace the lcd hinge on my Asus F3JC laptop, where can I buy in Australia
thanx fr t question,
step 1. unscrew the lcd bezel untightening the six screws.
step 2. pull out the lcd hinge cover
step 3. lay the lcd flat and unscrew the screws under the lcd slowly so that you dont damage the sensitive wiring
step4. if its left hinge unscrew the left screw if right vice versa
step 5. pull out the lcd hinge with a sharp object
step 6. insert the new lcd hinge and repeat procedure from 6 to 1
enjoy and remember to say thanks
Mar 01, 2010 | ASUS F3Jc Notebook
Side by side doors uneven at top
Hi Carol,
Interestingly enough, I answered a similar question just the other day. Maybe there's an outbreak of lazy factory technicians who "forget" to tighten the hinge brackets? Hmmmm. Makes on wonder...
Anyway, it's easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
(pssst!... don't forget to rate me, will ya? C'mon, throw me some love.)
May 29, 2009 | Frigidaire FRS26F4C Side by Side...
Hinge Replacement
Here is the complete procedure for a Toshiba A20, that is quite similar to A45. Follow same steps. Remove battery and power cord before starting.
Good luck.
Jul 19, 2008 | Toshiba Satellite A45-S150 Notebook
D600 Right Hinge
Hi!
is there a screw at the bottom of that? you can try to loosen it a bit ad turn it. if not, then there might be really a problem on that hinge that might need to be replaced. try to call the sales dept where you ordered it and ask if they can still replace it.
let me know if it helps.
Karlox
May 20, 2008 | Dell Latitude D600 Notebook
Terca M1 Loose Display Hinge
The hinge can't be repaired, but it can be replaced. It's feasible to do it yourself if you're tech savy. Just look online for guides that show you how to replace the hinge on any laptop and you should get an idea how to do the replacement step by step for this specific model. Most hinge mechanisms use the same system. I work for Computer Repair NYC and i have to fix this problem a lot, you can get the hinge on ebay.
Mar 03, 2008 | Toshiba Tecra M1 PC Laptops
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
