When I turn my washing machine on the lights come on but when I hit start nothing happens, I've tried all different cycles, checked taps, unplugged and plugged it in but still nothing.
  • Washing Mach... Master
  • 1,527 Answers
Hello, first check the door interlock make sure theres good contact if ok ,then check the belt at the back of the washer it might have come off or snaped. is there a humming sound coming from the machine if so it could be the brushes on the motor. 2 the plastic block sit either side of the motor these are made of carbon and wear down can cause the motor to stop working. if this ok with the power check the cables inside the washer that connect to the circuit boards make sure the good connections hope it helps
regards
shaun
Posted on Mar 26, 2011
Whirlpool Cabria: Power is getting to machine, but when you hit start button...nothing happens.
Sounds like something is jammed and overloading the machine. Check for locked motor.
Dec 21, 2017 | Whirlpool Washing Machines
Zanussi aquacycle 1200
Turn the machine to the off position. Unplug it and then plug it back in. Now try to restart the cycle. If this does not help find a local washer and dryer repair shop
Jan 24, 2014 | Washing Machines
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Jun 09, 2013 | Frigidaire Washing Machines
Cabrio washer will not start
I have one doing the same thing it washes but will not rinse.So until I can do better I just use the wash cycle twice first with detergent and once without.
May 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My machine doesn't run. Sounds like it's trying...
http://appliancejunk.com/ge/washer/31-9135.pdf
Above is your service and repair manual, this is what the engineers use to troubleshoot and repair these units. Below, and two DIY self help washer repair self help websites. http://www.repairclinic.com/Washing-Machine-Repair-Help
http://www.washerhelp.co.uk/diy-repair-help.html
Jun 01, 2010 | General Electric WSSH300G Front Load...
No power
test the outlet with something else (lamp, voltmeter, etc) If no power, check the breaker. If you have power, try holding the button in for a few seconds, but make sure the door is latched well first. Try to start it on a different cycle.
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Omega wd1052 won't start cycle
Does the machine fill with water? If not see if the tap is turned on.
Possibly the drive belt could have come off or there could be another issue, but need more info on the problem exactly.
Jun 17, 2009 | Washing Machines
Hot point wmlt80, dail clicking and turning, cycle wont start,
Yes, I work for GE what you need to do is to resent the appliance. Something should had happened with the computer of the washer. Just unplugged the machine for 40 seconds. You can unplugged or turn off the circuit breaker for 40 second and plugged back in. Select a normal cycle and let it run.
Jan 15, 2009 | Hotpoint WMTL80 Top Load Washer
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
