Question about Medion MD95210 COMPATIBLE LAPTOP LCD SCREEN 17" WXGA+ MATTE CCFL PC Notebook
How do i get my laptop to work again i changed something with the resolution and it comes on then the screen goes blank
    Novelist:
  • 107 Answers
If you have an external monitor, it would be easiest to hook it up to the laptop and hope that you get video on the external monitor. This would make it rather quick and simple to change the resolution back to something your laptop can handle. If you don't have another monitor that you can use sitting about, the best resolution would be to restart the laptop, and press F8 as the computer is turning on. This will give you a list of different options to boot into Windows with. One of the options will be a "VGA Low - Res mode", use the arrow keys to navigate and enter to select that. You can then change your resolution / restart and set it to what you want it to be from there.
Posted on Mar 26, 2011
When booting, screen is divided horizontally so I get two images. When I log into Windows XP, screen goes blank. I can use an external monitor, but laptop screen won't work correctly.
The GPU and system is working, you have proved that with the external monitor. A quick check is to change the resolution to something like 800 x 600. If it is then OK, download a new video driver. If still faulty, replace the screen. Ebay will get you one quite cheaply and utube will show you how to replace it.
Sep 10, 2014 | Dell Vostro 1520 Notebook
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
Blank screen on my Dell Inspiron 1545
if your getting your dell logo it means your disply is working fine
may be u r windows is not working properly just try to up-date your windows with any windows disk
Apr 25, 2010 | Dell Inspiron 1545 Notebook
I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned ON the...
Try to do this: Just before the Windows start up screen (after the bios loading) press F8 and log in at safe mode settings. If at this mode you can see your screen change the resolution settings at a lower set. Save and reboot normally. Now try step by step to increase your resolution. In case of a blank screen appears at a new setting, don't do anything; after some seconds the monitor will come back to the previous settings. Save and go on.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 05, 2010 | CTX S762A 17" LCD Monitor
My computer begins to load windows, then after the screen with the windows logo and bars goes away my screen goes black.
Nine times out of ten if that's when your display stops, it's simply because your display settings are set to something that your monitor can't handle. Depending on what it's not supporting, some monitors respond by going black ... others just go "crazy" displaying unintelligible gibberish.
If that's the problem, it's fairly easy to fix.
First things first ... let's get you a bootable system.
Boot in safe mode - press F8 when the Windows loader presents you with the 30 second list of choices, and then select "Safe Mode" as your boot option.
Right click on the desktop and click Properties, and then on the Settings tab.
Now click and drag the Screen Resolution slider to the far left ... you want the smallest settings that your screen will support. Typically that'll be 640x480, or 800x600.
Also change the Color Quality dropdown to 256 colors, or whatever is lowest. (You probably don't need to go as low as 16 colors, if that's presented as an option.)
Now, click on the Advanced button, and then the Monitor tab of the resulting dialog box. Change the Screen refresh rate to 60 Hertz.
OK your way back out, and reboot your machine. If these setting were the source of the problem, it should now be able to boot normally. You may not like the screen settings, but at least you now have a place to start.
"Start experimenting with the settings to see what does, and does not, work with your monitor."
If the display is still blank or gibberish, the my recommendation is to once again boot into Safe Mode, possibly Safe Mode with networking, and update your video display drivers. It's likely that they are incorrect or otherwise broken. Now start experimenting with the settings to see what does, and does not, work with your monitor.
I tend to start with the screen resolution. Once again right click on the desktop and click Properties, then Settings, and then drag the Screen Resolution slider a notch or two to the right to increase your display resolution. Now click Apply. It should change the resolution and display a small message box asking if you want to accept this setting. If you don't respond within some time, it assumes you can't see it, so it resets to the previous setting. If the screen goes blank or you can't read it, wait at least one minute before doing anything. The problem may resolve itself, and you'll be able to say "well, that resolution doesn't work", and move on to try another.
If, after a full minute or more the screen remains blank or unreadable, you'll have to reboot into safe mode, as we did originally, to restore your setting. (Why might this happen? Windows "remembers" and doesn't bother to ask you if you reset to something that you previously said worked. If you mistakenly said "this works" when it didn't ... perhaps by random keyboarding while the display was blank ... well, that could be how we got here in the first place.) You can repeat this process of trial and error for each of the screen resolution, the color depth and the screen refresh rate. (For CRT displays, you really do want the refresh rate to be as high as your monitor supports.)
Nov 28, 2009 | Dell Latitude D800 Notebook
All explain it better , my laptop was not working at first so i did a recovery to go back to a time where i left of and everything was fine. after that i recently restarted it the computer again then i...
Sounds like the laptop is trying to display a resolution that is not supported. Try to reboot into safe mode or the BIOS. Try safe mode and if you can get into safe mode make the default screen resolution something like 1024 x 768, then reboot and see if everything comes back.
Aug 24, 2009 | HP G60-120US Laptop
The screen goes blank after 5 seconds
Make sure you have the correct drivers install for you video card. Also, check to make sure your resolution is not set to high for you video card. To get to resolution; right click on Desktop > click Properties > press Settings Tab, from there you can move the slider to change your screen resolution (try different resolutions until it doesn't shut off anymore).
Let me know.
Jul 09, 2009 | ViewSonic VG900b 19" LCD Monitor
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
Medion MD95210 COMPATIBLE LAPTOP LCD SCREEN 17" WXGA+ MATTE CCFL PC Notebook Logo
67 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
