Question about Spec Research Chicony 9820X (KB-9820) Keyboard
Hi. KB9820 mouse doesnt work - the keyboard works fine. Conected to laptop wuth the "2Ps2toUsb" cable. Thank You
Acer 5570z keyboard is locked..Mouse works fine. Tried it in safe mode..keyboard still wont work..but mouse will...Even reloaded the operating system and keyboard still doesnt work..
Hook an external keyboard to the laptop, if okay! replace the laptop keyboard. If no change check bios setting to make sure the laptop is not disabled, and reset bios to factory default.
Mar 10, 2012 | Acer Computers & Internet
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
My keyboard neither mouse are not connecting my computer it just doesnt show up i have a remote that connects to the same usb sender perfectly fine but the mouse and keyboard wont. Thank you,
its hardware problem, may be water or any liquid get inside and make the keyboard not work state, do you have any function key to disable keyboard or mouse mean go to control panel -> hardware setting check whether mouse was disable or not, if it disable mean make it enable so that your mouse works good same for keyboard.
Good luck
Dec 30, 2010 | Acer NSK8458AN Keyboard
Laptop keyboard doesnt work extensa 5220 laptop . Keyboard keys do nothingboots up fine and mouse functions fine can get on facebook but cant type anything.
shutdown unit, remove battery and remove keyboard assembly, check for possible lost contact ribbon wired slots.
May 15, 2010 | Computers & Internet
I have cordless key board i put a new battaries still doesnt work do you think the key board doesnt work
To fix the problem,
please press the connect connect button on the bottom of the mouse and the connect button on the reciever and relaese both the buttons together. this would rest the wireless connection and then the mouse should work fine.
regards.
Jan 29, 2010 | HP Multimedia Cordless Keyboard/Mouse...
The keyboard dosent work when starting up my
Without looking at the laptop it's difficult to diagnose the problem, but a temporary solution is to borrow/buy a cheap USB keyboard and mouse to get you up and running.
Jan 20, 2010 | Acer Aspire 5670 Notebook
I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Mar 11, 2009 | Targus PAWM001U Mouse
Mouse not working
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this than do this
  1. select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Mar 14, 2008 | Computers & Internet
My ex110 combo came without any instructions, how do I at least get started?
Did you put batteries in both units before connecting the Receiver to a USB port?
Then did you use the CD software program that came with the keyboard and mouse and install the program?
After doing the install the following info will help to make them operational.
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Nov 05, 2007 | Computers & Internet
Spec Research Chicony 9820X (KB-9820) Keyboard Logo
26 people viewed this question
Top Spec Research Computers & Internet Experts
David Payne
David Payne
Are you a Spec Research Computer and Internet Expert? Answer questions, earn points and help others
