Question about Behringer EUROPOWER EP2500 Amplifier
Frozen/welded power on/off switch
The power switch in our Church's EP2500 amplifier froze/welded in the ON position. I replaced it with another SPST 15 amp switch and it welded the first time it was turned ON.
The unit has what looks like an input power surge suppressor but I can't identify it. Could it have failed? Where can I get a match (or bigger) one?
  • rafael13 May 12, 2009
    I have the same situation, the HOUSE Amp for my church is having the same problem the ON/OFF switch got stuck in the ON position, the Amp is working fine. But my concern is that, if one day before service the Amp dies we are going to be in truble that is why Im looking the solution here so you guys can help me. I really apreciate any advise or tip in how to fix this little Issue. Thanks
    Champion:
  • 232 Answers
Sorry your amplifier has and internal short and can only be repaired by a repair shop if its cost worthy. Putting a bigger switch will only provide more current to the source resulting in the same thing or a fire from the feedback of current creating heat at the weakest point in the circuit
Posted on Aug 04, 2008
My EP2500 keeps on blowing a fuse on the right channel and I opened it and realised that the two horizontal caps are a bit bigger.
They wouldn't blow the fuse. You are looking at the main devices that power the channel. If you put an ohmmeter on their terminals (assuming they are transistors) then it will show like you have touched the two test probes together. If it does replace the part(s).
Oct 24, 2013 | Behringer EUROPOWER EP2500 Amplifier
Ep2500 15volt missing
Post voltages on R64/R61
then D68
then T44
and D76
Sep 08, 2012 | Behringer EUROPOWER EP2500 Amplifier
I have EP2500 amp i want to use it to push 6 tops, what should i switch it to? one channel must push 3 tops and the other as well pushing 3 tops.
OK, you can use ep2500 amp to power 3 tops each,But the only challenge is that you are about to over load your amplifier. might get hot too fast .
You can use a cooling system to make it not too hot..It also depends on how the event your using it for...Using 3 EP2500 amplifier to drive three 6 top, using two top for each amplifier. Just a suggestion.
Using 2 amplifier, you will need to drive on one channel to drive 2 tops, and 1 top for the other channel.
That will do. But make sure you turn on the volume of the amplifier to the max volume ,so that it will be able to work properly for your tops...
Mar 31, 2011 | Behringer EUROPOWER EP2500 Amplifier
How to power up a compaq 243890-001 power supply without the the motherboard? Its not green to ground
Remove Power Supply
1 . Shut down your computer and unplug the power cord and all cables connected to the system.
2 . Open the computer case and disconnect all power connectors from the motherboard, drives, cards and fans.
3 . Remove the four screws that secure the power supply to the case. These screws are located on the back of the computer case, at each corner of the power supply.
Wire and Start Power Supply
1 . Switch the power supply to the "Off" (sometimes "O") setting.
2 . Insert the end of one wire from a single pole, single throw (SPST) switch into the green wire of the ATX power connector (the largest power supply connector).
3 . Insert the end of the other wire from the SPST switch into the black wire of the ATX power connector. If your power supply has two black wires, connect the SPST to the black wire directly beside the green wire.
4 . Wrap electrical tape around the ATX power connector and wires from the SPST switch to hold them in place. Make sure there is no exposed copper or silver wire from the SPST switch wires.
5 . Turn the SPST switch to the "Off" position, if not already set. Plug the power supply into the wall outlet and switch it to the "On" (sometimes "I")setting.
6 . Connect any other computer components that you wish to operate without the motherboard, such as fans, drives or cards. Turn the SPST to the "On" setting to activate the power supply.
Hope the above information will be helpful to you.
Thanks.
Dec 01, 2010 | Compaq (243890-001) 250-Watt Power Supply
Trips on power up
It has a short circuit on the final steps of the outputs, maybe the common called "final transistors or power amplification IC (integrated Circuits)"are blown. You don't have the ability to resolve this problem, so take the unit to a facility authorized repair.
Dec 29, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EP2500 trips immediately when turned on
Power supply section is overloading probably because of audio power amp problem.
Paul
Mar 31, 2009 | Behringer EUROPOWER EP2500 Amplifier
Europower Beringer PMH3000 power turns on then turn off?
when you turn on the AMP and the red light comes on give the amp 2 seconds and turn it back on the red light should turn off. That is what I do with the amps at my church and it works for me, I hope that this works for you too.
Mar 25, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
67 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
