Question about Freezers
My beverage air refrigator ri18 compressor turns on sounds like it works but doesnt get cold
    Problem Solver:
  • 53 Answers
1) Check the compressor working or not.. Air cooling type condenser fan may be not working properly.
2) Compressor working but not properly. Last side of condenser (Filter) Light Heat or not.
3) Inside Cooling area do not get cooling. may be gas leakage problem.
4) My opinion check Gas pressure Low and high side.
Posted on Mar 26, 2011
Turn fridge into freezer
Not really. UCR means under counter refrig. It could freeze some products, like lettuce, but the unit will not function for long periods of time as there is not defrost cycle and it will freeze up.
Jul 22, 2010 | Beverage-Air 6.2 cu. ft. / 176 liter...
Fan runs but the compressor does not run no
While moving the unit you may have jammed or budged the start capacitor which is keeping your unit from turning on. It is located in the back of the unit near the compressor it is oval shaped and silver in color with two wires running out of it. Get the number off of it, go online and search for beverage-air commercial freezer parts. You will need to have the model number to make sure that you get the right parts. Please rate
Jun 03, 2010 | Beverage-Air 11.8 cu. ft. / 334 liter...
Compressor does not kick on, low side reading just under 80 psi. compressor problem?
could be. Check out the start components first. They are cheaper and easier than a compressor replacement.
http://www.beverage-air.com/images/barEquipment/manuals/BB%20manual.pdf
try this site. It has your equipment manual and wiring diagram.
Hope this helps. Let me know if I can be of further service.
Jan 29, 2010 | Beverage-Air Freezer GF48L
Compressor start for a few second and cut off and start again. whats wrong . berverage-air freezzer single door model no. ef24-1as
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Dec 09, 2009 | Beverage-Air Freezers
Beverage air model sur27 refrigerator r134a powers on but doesn't get cold. compressor doesn't get cold not sure maybe it's the relay........if and when the ploblem is solved, is it hard to get parts for...
The larger pipe on compressor should get cold. The smaller should get warm to very hot depending on ambient conditions. Parts should be available, including a universal relay kit I could hook you up with. First determine if the compressor is running. Let me know. :)
Sep 19, 2009 | Freezers
Everything works fine, except when the compressor kicks in the panel breaker trips.
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
May 27, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Frigidaire Freezer is not getting cold LFFU1765DW9
try to vacum the coils on back, if thats the problem u will feel them get a little warm if this doesnt work try to tap the relay next to your compressor, i had this same problem
Aug 28, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
What do I do?
There is a thermostat control but your problem sounds like a system that is low on refrigerant charge. If it cools down to 55°F the compressor is working. If the system is low on refrigerant it has a leak which must be found and repaired before it is operated.
May 31, 2008 | Beverage-Air 74 cu. ft. / 2095 liter...
Freezers Logo
69 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
