Question about Orion Televison & Video
The tv works fine sometimes but then the picture becomes distored on one side, jumping and fuzzy, there is no pattern to it and it is happening a lot i have reconnected all the wires but it doesnt help
  • Orion Master
  • 17,130 Answers
Once the board warms up or the circuits works up ,t here are some components , can be active or passive that seems to go weak in the set value.
So imagine that it is the heat that changes the parameters of the board as the weak component which can be a capacitor or a IC decides to break down.
Identify the section and pin point by using a simulated heat on suspected sections which will help to identify the component .
replace suspected capacitors in this section, suspect IC's if they heat up more than required.
Posted on Mar 26, 2011
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
LG 50PX1D Plasma TV with dark and fuzzy picture
Z-Sustain PCB will cure it.
It is inside the TV, on the Right Hand Side.
www.chsinteractive.co.uk or Google for a replacement.
Sep 08, 2009 | LG 50PX1D 50 in. Plasma Television
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Fuzzy picture on TV and NES when new RF adapter is cconnected
i had the same problem, and it was the rf unit itself. to resolve this problem i went to radio shack and purchased a special connecter. one side is an rca (male) to rf (female). when attached to a standard peice of cable wire, it acts as an rf unit. Also works with the sega genesis. hope that helped
Mar 30, 2009 | Nintendo NES Console
Vizio makes loud static noise, picture goes fuzzy.
You should check your home wiring and grounding. Also be aware of anything that has recently been turned on when this happens. Anyone using a microvwave, cell phone, or other appliance that might be causing the interference.
Mar 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Sony KV-32XB25 Distorted Picture
In most of the case, the problem is a defective LCD panel, if is it, there is not worth to fix.
Aug 02, 2017 | Sony KV-32XBR250 TV
Blurry/Fuzzy Picture/Double Vision after power outage
Hello stevenkgray and ADIMEN,
I think what has happened is the your TVs are out of focus which could be due to a voltage problem. First I would warn you that this is a problem in the High voltage section of your TV and caution should be taken, in fact I would suggest that if you do not have a background in electronics that you get the TV checked and fix by a qualified TV repair technician. However if you do have a background the next few lines will make sense and you might be able to effect these repairs yourself.
Items needed for troubleshooting:
Schematic Diagram
Multimeter
High Voltage probe (40Kv)
Universal Video Analyzer (UVA)
1) Unplug the TV and take the back off of it
2) connect the UVA to the tuner F connector and setup the UVA to send a test pattern into the TV
3) Power the TV back up and turn to the channel set on the UVA
4) check the anode voltage on the CRT with the HV probe (connected to the Multimeter set to volts and grounded) and compare it to the voltage on the schematic.
5) If the voltage is not right adjust the focus and screen controls on the Integrated High Voltage Transformer (IHVT) to obtain the proper voltage.
6) Check the pattern to see if it is still fuzzy.
If the pattern is still fuzzy you may have to inspect/replace the IHVT and or its associative circuitry.
If you suspect that the IHVT is bad you can perform a ring test on the transformer using the UVA. (The instructions on how to do this are on the UVA quick steps pull out. or the instructions can be looked up on the web.
I hope this helps
Thank you,
Shuttle83
Jun 24, 2008 | Philips 60P8341 60" Rear Projection...
Purple and white distorted fuzzy lines running up and down and side to side on tv
I just had my lower Y-buffer board swapped out to fix a problem similar to yours. After an hour and a half of on-time, the lower half of the screen would flicker on and off with the same appearance you mentioned. Changing out this particular board fixed it for me. However, since it has gone from top to bottom on your set, it may be more of a main board problem for you (that controls both upper and lower halves). Beyond this, I don't know any more. I am considering getting a service manual to gain more knowledge about the various PCBs in the unit so I can fix any future problems myself.
Aug 19, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
76 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
