Question about GPS
LOW GPS SIGNAL DOES NOT WORK MODEL GM408 - GPS
Igo sat nav cant get gps signal ,it was working fine untill november 2009,now it does not pick up gps signal
The mosdt common reason for non connection is low battery power. The battery lasts approx 2 years and may not be charging correctly. Try changing to a new battery.
Second reason is that it is not on the right port, consult manual for your model and set it to its correct port and BAUD rate.
Finally if you have started the enginbe with it connected to the 12v car outlet you may have damaged the chip.
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Navigon GPS MobileNavigator 5 Base Car GPS...
No valid GPS signal for two days, what I can do?
You can try a reset Check in the manual where the reset hole is i thinlk this model is under the scfreen surround which is removable.
This will take ut back to factory settings, you might want to check if its set to the right PORT and BAUD try this
GPS Program Port: COM1
GPS Hardware Port: COM9
Baud Rate: 4880
Manage GPS Automatically (Ticked)
Now other reasons are low battery= low signal//fully charge the battery
no signal from satellites= damaged SIIRF chip caused by plugging into car power when starting engine...needs new m/board
Maximum time to access 1-9 minutes max...
Please rate my help++++Thanks for using FIXYA...
Dec 01, 2009 | Tomtom ONE GPS Receiver
Me2
3 things and 1 is serious
Not a clear view of the sky...
Batteries are too low to read a satellite signal fully charge the unit
The SIIRF chip is damaged.. Expensiive!
If you put it into car power and start engine it will damage the unit and one day you will turn it off and then on and it will never work again
Better hope its just a low battery
Please rate our help to keep FREE service online
Aug 30, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
Distinator gps can not find GPS signal (say's signal o low)
Not sure what model you have But if its the A600 /01or 5210 and you are running destinator 6.0 or higher you first need to recharge the battery so that it shows 5 bars on the battery icon. Low signal can be from a bad or low battery. a faulty antenna ( flip out)
I am the distributor for these GPS in Australia. If you need a new battery contact me as i am now the only one with these batteries.
I also recommend you get one of our 50Db antennas The skymaster. to help improve the signal and take some of the load off the battery. Do not use those cheap Chinese antennas as they are only 28Db and cause more lag than they are worth.
the site is Marbella Australia contactt me from there
Jul 30, 2009 | ASUS MyPal A696 GPS Receiver
When I turn on my TomTom, it says GPS signal lost for about 3-4 minutes before it picks a signal up. This happens everytime no matter where I am. Then it works fine.
Does your GPS have a good view of the sky?
i.e. not mounted low on the dash of your car.
it really only needs to find 3 satellites to work but it might take a while to lock on if reception is low.
When you say every time you turn it on. I assume that you don't go days without turning it on. A GPS stores information about satellites and their orbits across the sky and keeps it for about 6 days. The download process of this information is fairly slow. If you run it most days the information gets updated while the gps is running so you tend not to notice.
Just some ideas to think about.
Jul 08, 2009 | Tomtom ONE GPS Receiver
No valid gps signal
battery may be too low recharge it
Jun 28, 2009 | Tomtom ONE GPS Receiver
Omnitech Model 16878 GPS ''waiting for GPS signal''
There is a firmware update to correct this issue, if you are still having it.
Jun 20, 2009 | GPS
My tomtom cant find any satellites and keeps saying waiting on valid gps signal......
check the port is set to 8
not sure if your model has GPS search wher it finds the port and vbaude automativcally, if it does use it and see if that fixes it if not
your battery is too low
you have a damaged SIIRF chip and that is expensive to repair
Jun 01, 2009 | Tomtom ONE GPS Receiver
GPS Signal low
ensure you update quickgps in programs menu every 6 days to ensure best gps reception
Jan 24, 2009 | HTC Touch Diamond Smartphone
GPS Logo
78 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
