Question about Bosch Washing Machines
Our excell 12oo washing machine is showing a key symbol we can open and close the door but the washer wont go onto any wash
    Brigadier General:
  • 6,277 Answers
I suspect that there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. I'm sorry but both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Mar 26, 2011
Hotpoint washer wont work
From the manual page 24:
'Door' is flashing in the display window...
?Shut the door firmly, until it clicks.
The symbol should now go out.
I suspect the door sensor has failed. It thinks you haven't closed the door, so it refuses to do anything at all. It's called a Door Interlock, it has a switch or sensor built into it.
First try unplugging the washer for 60 seconds and plugging back in to try to reset the controller. (Dry hands only!)
If the door interlock is a simple switch, you should be able to check it with an ohmmeter. I would check it first before buying a new one.
The part number is HPTC00085194 or C00085194, here are a couple places you can buy one. You can also find them on ebay.
Washing Machine Door Interlockby Indesit
Door Interlock Washing Machine
WASHING MACHINE DOOR INTERLOCK C00085194 design may vary
Sep 21, 2016 | Hotpoint Ultima WF860 Front Load Washer
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
DAEWOO,WASHING MACHINE.CDW-WD13WCS/RCS. Door will
This video will show you how to open your DAEWOO washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 02, 2013 | Daewoo DW500M Top Load Washer
Hotpoint wf840 not starting
Machine may not be finding the signal from the door interlock, check the wire connections to it.
Dec 29, 2012 | Hotpoint Ultima WF860 Front Load Washer
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
Bosch washing machine classix 6 Stopped working. wont let me program it. A key symbol flashes on
I believe that the key symbool indicates that the machine cannot lock the door. Sometimes the result of a slightly sticking door interlock mechanism. Open the door and close it hard and firmly (slam it a bit, but don't get silly about it!). A good test to see if this is the problem is to attempt a program with the door swinging open. If the symptoms (flashing key) are the same, then the issue is almost certainly narrowed down to that door lock mechanism.
If this fails, unplug the machine from the main power source and leave it for 20 minutes to allow it to reset its self, then try again.
Jul 11, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Key Symbol appearing and cycle wont start
Please see if there is a lock installed into for safety. Press and hold power/start/pause as power is plugged.
Make sure that the door switch is working open and close once again to check as this can also stop the machine from operating.
Mar 02, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Unable to use washer due to key logo 'flashing'. Have checked the plug at bottom right of machine no blockage there.
Please try this
the key and flashing = child lock.
close washing machine door, turn to normal setting, press the power switch and keep pressing for several seconds. The symbol should disappear and the beeping should stop.
Than You
Sep 08, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
