Question about HP DeskJet 1220c InkJet Printer
My power light ,resume light and ink light keep flashing? i tried to print photo and kept sounding like it was printing but no picture and lights started flashing
  • 1,027 Answers
One of the ink cartridge is defective. If you lift the front cover, the cartridges stop position You will indicate which of them is defective (by the drawings on the printer).
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Posted on Mar 26, 2011
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Waste ink absorber full
you can reset the ink counter but make sure u find way to replace the pad else it's going to be messy once the ink leak out...below is how you reset your waste ink...
1. Turn off printer.
2. Press the button Resume/Cancel(dont release) then press POWER button- if done, you will see the light change to green color.
3. Release the Resume/Cancel button, but dont release the POWER button.
4. Press Resume/Cancel button of 2 times, while still pressing the POWER button, after that, release both.
5. When the light change to GREEN - press the button Resume/Cancel 4 times.. then press POWER button once.
6. Turn off printer
7. Turn on and try print.
May 26, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
5 yellow blinlking lights. Power on/off doesn't clear the lights. Won't print. TIA...
Canon IP3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Can try it may work all the best of luck
Feb 15, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon I850 won't print , it has a green light for about 2 seconds then flashes a yellow light for about 6 seconds
Hi there
This is only a try it may do it but I not know,
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i850)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 19, 2010 | Canon i850 InkJet Photo Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
2. Release RESUME
0 presses - green - Test print (or exit service mode on i960)
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Hello. I get 8 yellow flashes indicating the ink
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power
button. The indicator will blink in green and remain lit in green.
3) Press resume 4 times (Green) for Waste ink counter reset.
4) Press the power button. The printer will switch itself off after performing the function.
Or try
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 07, 2009 | Canon i950 InkJet Photo Printer
Orange light is flashing 7 times, but printer ,is locked. Ink tanks do not centre when lid is opened.
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
hope this helps
Sep 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Can not print from my Cannon i950. 'paper thikness lever position
A friend of mine had the same problem and turned out to be the print head. They can be pricey so a new printer would be in order probably. Could also be the waste ink counter as well. Here are some steps to see if you can get rid of the 7 orange blinks:
3. Release RESUME
If this doesn't work then you know its the print head for sure.
Feb 10, 2009 | Canon i950 InkJet Photo Printer
Problem with Canon MultiPASS F80
On the right side of the print cartridge carriage there are two small felt ink pads. When they fill with ink somehow the machine detects it. Mine started with the flashing light and check printer error code and then progressed to a nasty grinding sound everytime I hit resume or tried to reset the counter. I thought all was lost, but kept trying. I found two pads, one square and one rectangular. They aren't very spongy but they are full of ink. They are only about an inch across. I got them out without taking the printer apart and repeatedly soaked them in a little water until the water was clear, then I let them dry and replaced them in the little trays where they came from. I cleaned the plastic fins that were nearby and coated with ink with a Qtip and rubbing alcohol. And I removed the print head and cleaned the muck of ink on the connectors with a Qtip and rubbing alcohol. Much to my suprise, after all of this the damn thing worked fine again when I plugged it back in.
Apr 14, 2008 | Canon MultiPASS F80 All-In-One InkJet...
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
HP DeskJet 1220c InkJet Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
