Question about Sharp Microwave Ovens
The Sharp Microwave Oven R-9H20 Made in Japan is not rotating. The centre knob seems to be broken - it is coming off. Can I get the spare part - ie the plastic crentre knob
MicrowaveSvc
  • 9098 Answers
SOURCE: The door of my Kitchen
The door latch heads (prods) are not making proper contact with the door switches, so it will not work right.
The latch heads need to be replaced.
You can order parts for this Canadian model here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 02, 2008
  • 3230 Answers
SOURCE: Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Posted on Aug 24, 2009
heatman101
  • 43501 Answers
SOURCE: SHARP Microwave- doesn't rotate, fan does not come
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: My sharp microwave oven model
Sorry to read about your problem, I hope this helps you out.
Try getting your parts here, www.aplusapplianceparts.com and use this coupon code 1051 for a discount. 1
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
MicrowaveSvc
  • 9098 Answers
SOURCE: sharp microwave oven r-9h20 display flash(00:00))
On Sharp R-9H-series ovens, when the membrane keypad fails, as in your case, since these parts are no longer available, the oven would have to be retired.
Sorry to bring you bad news. These were great old workhorses.
Posted on Oct 06, 2011
MODEL R-395Y sharp carousel microwave not working. All power outlets are fine. Please help, cheers lyn
I was unable to locate a service repair manual specific to your microwave; sorry.
You'll must likely have to find a Sharp service and repair center.
I've attached a link that contains the user's manual to your microwave...it has the phone number and address of Sharp; perhaps you can phone them and ask where a repair center is located.
This is the diagnostic check list Sharp recommends before calling for service:
SERVICE CALL CHECK
Please check the following before calling for service:
1. Does the display light up?
2. When the door is opened, does the oven lamp come on?
3. Place one cup of water (approx. 250 ml) in a glass measure in the oven and close the door securely. Oven
lamp should go off if door is closed properly. Press the INSTANT COOK/START pad once.
A. Does the oven lamp come on?
B. Does the cooling fan work?
(Put your hand over the rear ventilation openings.)
C. Does the turntable rotate?
(The turntable can rotate clockwise or counterclockwise. This is quite normal.)
D. After one minute, did an audible signal sound and COOK
indicator go off?
E. Is the water inside the oven hot?
If "NO" is the answer to any of the above questions, please check your wall socket and the fuse in your meter box.
If both the wall socket and the fuse are functioning properly, CONTACT YOUR NEAREST SERVICE CENTRE
APPROVED BY SHARP.
Sharp Carousel 395Y Operation Manual And Cookbook
Feb 22, 2017 | Sharp Microwave Ovens
Sharp microwave oven flashes 88:88 touch pad does not respond , model R-9H20
You have a failed membrane keypad.
Replacement keypads are no longer available for any Sharp R-9H-series microwave ovens.
The oven will have to be replaced.
Nov 19, 2016 | Sharp Microwave Ovens
Why my sharp r 9h20 microwave oven noyzey during operation?
You are probably referring to the cycling of the klystrom in order to maintain the power lever you have chosen. The noise is characteristic of yours and other cycling type ovens. For a quieter operation that is not "all off" and "all on" in succession, try a DC powered next time. Panasonic makes one called Inverter...maintains cooking level without switching.
Nov 10, 2014 | Microwave Ovens
Sharp microwave oven r-9h20 display flash(00:00)) and no keypress action
Sep 04, 2011 | Microwave Ovens
My sharp microwave oven model no: R-9H20 needs to be replaced with a new feather touch pannel. Is the spare part available in market. If so where can i buy it.
3 Thumbs - Helpful
Jan 02, 2011 | Sharp R-1480 Microwave Oven
Microwave owen SHARP Model R9H20 Digital START button is not working. Need Workshop address in Dammam or Al-Khobar, Saudi Arabia including phone numbers to fix the problem.
R-9H20 (W) sharp microwave oven- the turn plate does not work kindly let me know what needs to be done. i need help. Kindly e-mail me .
zaffarlone@yahoo.com
Zaffar Iqbal
Dec 18, 2010 | Sharp Microwave Ovens
SHARP Microwave- doesn't rotate, fan does not come on, oven light comes on, timer works
heatman101
Dec 07, 2009 | Sharp R-520KS Microwave Oven
Spare parts
go to appliance parts pro's website they're located in ohio
Aug 11, 2009 | Westpoint TV-258 Microwave Oven
Sharp R-9h91B microwave oven stopped working
If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Sep 28, 2008 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
