Question about Nokia E7 (16 GB) Smartphone
How to remove back cover and remove battery in nokia e7 ????
3 Suggested Answers
SOURCE: i am not open my
how to open back cover from e7
Posted on May 13, 2011
  • 96 Answers
SOURCE: how to open the battery casing of E7 Nokia.
Hi.. Just check out this following link http://www.youtube.com/watch?v=LNCwCHl0Uk0
Posted on Dec 12, 2011
I have forgotten my password for nokia e7 how can i hard reset
Follow the steps to hard reset nokia e7:
Before doing the master reset and format Nokia E7, ensure that you have backed up important data
1. The Nokia E7 battery should be charged fully
2. Turn Off Nokia E7
3. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
4. The Nokia E7 will reset
OR
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
GuruAid.com
Jan 04, 2015 | Nokia E71 Smartphone
Forgot my security code n i dont know how to reset it
Option 1, How to Hard Reset Nokia E7 with Software Menu:
  1. Turn On Nokia E7
  2. Go to Menu: Menu > Settings > Phone > Phone management > Factory settings > Delete data and restore
  3. Nokia E7 will ask the default security lock code is: 12345
  4. The rest will do by itself to master reset Nokia E7, this process will erase or wipe all important data
#Option 2, How to Hard Reset Nokia E7 with Hardware Button Combinations Key:
  1. Before doing the master reset and format Nokia E7, you have to backup any important data
  2. Battery Nokia E7 should full charge
  3. Turn Off Nokia E7
  4. Press and hold together: Volume Down Button key + Camera Button key + Menu Button key, after that continue with press Power Button (do not release the first three button)
  5. The process will do format to factory default Nokia E7
#Option 3, How to Hard Reset Nokia E7 with Secret Security Code:
  1. Make Sure Nokia E7 is already charge properly
  2. Turn on Nokia E7
  3. Press at Dial pad: *#7370# and wait
  4. Nokia E7 will ask for default security code, enter: 12345
  5. Nokai E7 will do format to factory default
How the Right Step to Flash and Restore Nokia E7 Unlock?
Have a good smartphone should know how to restore especially while the smartphone of Nokia E7 got problem. First step is do the soft reset first, if the Nokia E7 still get the problem, second try by doing the hard reset or restore to factory default with some options step above.
What should I do to Fix forgot or Lost Password of Nokia E7 Default Security Code?
If you never change the Nokia default security code is 12345, maybe sometime you every change the default security code and you forgot what you have change, in this case you have to go to nearest authorize service center for repair Nokia E7.
How to Restore Clean Setting at Nokia E7 Reinstall the Operating System?
Restoring the Clean setting of Nokia E7 can be done with doing the soft reset without delete any important data. If you want to reinstall clean operating system for Nokia E7, this can be done with doing the hard reset, but your data important will be deleted.
Help for Slow Respond Nokia E7, How to Make Nokia E7 Run Faster?
It will hurt to use slowly Nokia E7 smartphone, maybe it have a lot of applications or you ever try to setting the Nokia E7 with wrong way. This problem can make our Nokia E7 running slowly, so to make Nokia E7 run faster, you can try to do the soft reset and also hard reset. It depend on what the main problem with your Nokia E7.
How to Fix Forgot Nokia E7 Pin or Password ?
If you assign a pin or security password for Nokia E7 and forget about it, you have to do the hard reset of Nokia E7 with step above
The information from this page describe about nokia e7 hard reset,hard reset nokia e7,how to hard reset nokia E7,how to format nokia e7,how to reset nokia e7,e7 hard reset,hard reset e7,nokia e7 format code,nokia e7 hard reset button,how to unlock nokia e7 security code. If you need another resource for hard reset, use search function at this homepage or find from our related posts.
Mar 23, 2014 | Nokia E7 (16 GB) Smartphone
Reset password
  5. The process will do format to factory default Nokia E7.
Source: http://www.hard-reset.org/factory-default/how-to-easy-master-format-nokia-e7-with-safe-hard-reset/
Jan 15, 2014 | Nokia E7 (16 GB) Smartphone
My nokia e7 fell into water and won't turn on
Wet Cell Phone
Immediately remove the phone from the water, turn off the cell phone, remove the battery and SIM card. To dry out the cell phone put it in a large plastic bag with silica gel drying crystals then put it in a warm sunny place for several days or in front of a warm fan heater for several hours. Reassemble the phone and hope it will work properly again, but if does not work then it is faulty and you need a new cell phone.
Dec 26, 2012 | Nokia E7 (16 GB) Smartphone
How to force turn off on my nokia E7-00 when it fails to respond ?
Just hold the power button and the home button for like 10 seconds. I hate that nobody gives useful answers here, yahoo answers is way better.
Apr 24, 2012 | Nokia E7 (16 GB) Smartphone
My nokia e7 screen has gone to a black and green glitch back ground
Have you tried a reset by holding the power key down for 10 seconds?If that doesn't work you can try removing the battery for a few seconds.
I had a similar problem with my E7, it was dead and wouldn't respond even when I plugged it into my PC. But once I had removed and replaced the battery it was working fine and its not gone wrong since. Here's a good guide on removing and replacing the battery
Dec 28, 2011 | Nokia E7 (16 GB) Smartphone
My nokia e7 won't turn back on
I had the same problem with my E7, but after removing and replacing the battery it was fine. If you've already tried holding the power button down for 10 seconds then you'll need to follow the guide below..
Sep 27, 2011 | Nokia E7 (16 GB) Smartphone
The phone rings continuously and wouldn't stop. Also, can not open the cover and bring out the battery
I had a similar problem with my E7, if you've already tried holding the power button down for 10 seconds then you'll need to remove and replace the battery, that fixed mine straight away. Just follow the guide below
Aug 26, 2011 | Nokia E7 (16 GB) Smartphone
Nokia E7 (16 GB) Smartphone Logo
5,425 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
