Question about Meade ETX-105AT (420 x 105mm) Telescope
Hi I have a meade ETX 105 pe I can get the scope to move Alt motion with the controller but it wont move in the Azimuth position with the controller. Might I be doing something wrong
  • 3,186 Answers
This can be caused by 4 things-
A stuck button on the hand controller.
A bad hand controller cable
A burned out circuit board inside
A burned out Azimuth motor
(Long shot) bad firmware in the hand controller. DO a Reset and reload the firmware.
Try to borrow another hand controller and buy a new cable. If these two do not fix it then it's a mechanical problem or a circuit board problem inside the scope.
Meade can repair this but you will need to send them the scope:
http://www.meade.com/support/index.html
Posted on Mar 26, 2011
When trying to set up my telescope, in home position and when its looking for its first object the telescope does not move upwards or just using the keypad it wont move up. it makes noise as if it wants...
I assume you have tightened the DEC knob on the side of the fork.
Then the gears are not engaging properly inside the forkarm. The scope will need to be disassembled to fix it. Go to the "Mighty ETX" web site and start reading the posts on the ETX80.
http://www.weasner.com/etx/menu.html
Apr 14, 2011 | Meade ETX-80AT (240 x 80mm) Telescope
I am looking for someone in Michigan near Sunfield, I have a Meade ETX125PE that I would like someone to help me with. e-mail address is petew@cablespped.com and petew@twincityfoods.com.
Contact a local Astronomy club nearby and the members will help you with the scope.
http://www.astroleague.org/societies/list/MI
Also this is the general setup for the NON- PE version of this scope.
1. Do a calibrate motors
2. Train the drives
3. Take the scope outside and level the tripod.
4. Put the scope in the HOME position (read the manual)
5. Execute a 2 star alignment and center both stars.
Dec 29, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
Motor tries but cannot move on the horizontal. Moves fine on the vertical. Usage only in Alt/Az mode. Only have the electronic controller that came with the scope.
You did tighten the AZ clutch? You did start from the HOME position? (turn the scope Counterclockwise to the hard stop)
Then you will either have to send it back to Meade for repairs, or open the bottom of the base, and look inside and see if the AZ worm gear is actually meshing with the motor. It could have come loose.
Meade customer service:
Oct 08, 2010 | Meade ETX-125EC (500 x 127mm) Telescope
My MEADE etx 105 telescope remote wont turn on but my telescope will. Can you tell me what my problem is please.
Could be just a bad hand controller cable. Check with Meade for a new one.
www.meade.com
Sep 24, 2009 | Meade Optics
ETX125 PE new model. Elevation has totally stopped.
Could be that the DEC motor driver has died. That could be verified by swapping the connections between the RA and DEC. If the DEC now moves, then that is the problem. If not, then the DEC motor is bad.
Nov 17, 2008 | Meade ETX Premier Edition: ETX105 PE...
Azimuth motor gearing problem
Sounds like it could be that the worm gear is not meshing
Look here for guidelines in the internals
Oct 15, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
One of the gears in the Azimuth motor got a flat spot because the worm gear was adjusted too tight. It is a 24 tooth nylon straight gear, very small- only about 1 cm across, but if this gear isn't working...
Below is the contact information for Meade parts. They are the only reliable source unless you know a local dealer that you can trust.
http://www.meade.com/support/contact.html
Jerry G.
Meade Instruments Corporation
6001 Oak Canyon
Irvine, CA 92618
(800) 626-3233 (U.S.A. Only)
Fax: (949) 451-1460
Apr 30, 2008 | Meade ETX-90 (48x90 mm)
Meade ETX-105AT (420 x 105mm) Telescope Logo
207 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
