Question about ASUS AC Adapter- Universal Notebook AC Power Adapter (NBACA407D2) Power Supply
The pin in the laptop of my ASUS model G73JW that plugs into the AC charger has broken off twice. I sent it in once already and not two weeks later the same thing happened. I am not rough with my computers and have never had this problem before. I also notice that most of the other computers I have seen have a pin securely placed in the AC charger and NOT the computer housing. Anyone else have this problem?
    Habit-Forming:
  • 103 Answers
I've seen this issue on an HP computer before. For some odd reason, some models decided to use "cost efficient" housing around the AC power unit on the inside of the laptop housing. If you know how to replace it yourself, I would recommend just acquiring the piece and replacing it on your own. There are some sellers on eBay who do provide quality products which are assembled with the highest standards.
Posted on Jul 28, 2017
  • 96 Answers
SOURCE: Burning smell on my laptop
Unless you have the ability to to replace the plug connector part yourself, you will have to take it in to a shop who can do that kind of fine soldering for you. If nothing else is damaged, it should be ok with replacing just that burnt out part.
Posted on Jul 12, 2008
angelo_mlc
  • 1035 Answers
SOURCE: my eee pc charger did snow show a blue light when
In order for to check if the charger is working properly, you can remove the battery and use the charger only. and observe for about 1 to 2 hours if your computer did not shutdown then your charger is still good.
If you still have warranty with asus much better if you ask them to replace your charger and that's for free.
Posted on Mar 27, 2010
leusnerdus
  • 54 Answers
SOURCE: asus Eeee pc will not charge
Hi, try to discard the memory modules. then extract the battery and try without it. check the HDD by extracting it and trying to start the machine. If you dont detect any damaged component, then you have to review electronically the Motherboard.
Thanks for rating!!!
Posted on Apr 21, 2010
SOURCE: My ASUS Eee 1000HE netbook
it could be the pin on the inside of the machine. The jack is tiny and the pin may not be connecting to the proper wires any longer. I had a similar problem with a compaq laptop..it had to be soldered for a temporary fix, the netbook itself has to be taken in. It's the only flaw I see with these machines.
Posted on Feb 11, 2011
  • 1542 Answers
SOURCE: battery icon showing 0% available (plugged in,
Hi
I would be tempted to leave laptop switched off and turn power plug on to charge up the battery before i use it for a couple of hrs at least and hopefully this will put some charge into the battery
they say that if you continously use the laptop with the power cord plugged in then you could
remove the battery completly to extend the battery life and just use the cord
that way the battery will last many years longer
Posted on Mar 06, 2011
How to replace the video card
the video cards in laptops are soldered onto the board ( graphics chip ) if you have had an expert look at your laptop and pin pointed the problem is with the chip then you will have to have it reflow'd ( you have to heat it up to melt the solder under it on a flat surface )
May 22, 2015 | ASUS G73SW-A1 Republic of Gamers 17.3-Inch...
Asus g73jw black screen on boot up
That sounds like the GPU is cooked. The CPU is heating up trying to drive the GPU that is not responding.
Feb 13, 2014 | ASUS G73JW-XA1 17.3-Inch Gaming Laptop -...
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
http://www.batterysupport.com/asus-eee-pc-1005ha-jack-p-303527.html
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Regards,
joecoolvette
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
I have a Toshiba U500 00X laptop with 19V power supply which I do not have with me at the moment. I do have an ASUS 19V AC adapter with positive terminal on the inside of the circular plug. The diagram on...
Hi, what your toshiba laptop model and asus laptop model? You can use the asus ac adapter on your toshiba laptop only if the folllowing three conditions are met:
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
For the specifications of the two adapters, you may check it here:
http://www.chargerbuy.com, then decide if it will work or not.
Jul 07, 2011 | Computers & Internet
I have an Asus K70IJ notebook. The problem is that it does not power on even when the charger is plugged in. The charger light on the laptop does not come on. I have tried different chargers with the same...
Sounds like the power receptor is broken off inside. If you plug in the charging cable on the back, and it's "wiggly", I would venture to say that you will have to get it re-soldered.
Soldering at a shop can cost as much as a used (working) motherboard.
Good luck.
Mar 24, 2011 | TechFuel AC Adapter (ACNB90W1880) for Asus...
My keyboard on my ASUS g73jw-a1 no longer lights up. I turned it off once and it won't turn back on.
This looks as if its a newer model laptop. If it's w/in a year old, I would contact tech support as it may be hardware issues or a loose connection. They should be able to take you through troubleshooting steps. Otherwise, they may have you send it in for repairs.
Mar 12, 2011 | ASUS G73JW-A1 Notebook
My eee pc 1005hab was dropped on the floor breaking the charger while still in the port, i took the charger out, netbook still on and used it till the battery died. that was two weeks ago. i now have a new...
The jack inside the laptop where the power supply plugs into is broken. It will need to go to a computer tech for repair, chances are the jack will need to be replaced and in order to do that a total dis-mantling will need to be done.
Jan 05, 2011 | ASUS Computers & Internet
HP DV6915nr AC charger does not turn on or charge the battery.
You have a defective regulating circuit on the mother board that will not allow charging or a broken connector pin at power connection .
Aug 13, 2009 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
