Question about Emerson UPStation GXT 3000RT (GXT3000RT-120) UPS System
My ups rt2000, line input power ok,green light glowing, no output 230vac
    Novelist:
  • 169 Answers
Check this with multilink
this will interogate the systems and report the fault or at least show you where it is.
You can get multilink from Emerson.com following the route to UPS software.
You have to have the correct serial cable or it will not work, cables come with units when new.
Sorry I do not know the pin out but if you are really stuck I can check Monday at me shop.
Hope this helps, thanks for using FixYa
Please vote for this if you like it.
Posted on Mar 26, 2011
Tda9380ps /n3/3/1664 using in sharp tv power supply ok , EHTok ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Oct 29, 2016 | Sharp Televison & Video
Using tda 9380 sharp CTV power OK Eht OK ,but green light few seconds and than red light
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jan 29, 2016 | Sharp Televison & Video
Tda9380ps /n3/3/using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light please to help send circuit diagram and IC pin configaration
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Give a special attention to this transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 19, 2015 | Sharp Televison & Video
Fault Light/ inverter failure
the current from the 12volt supply is not sufficient try a fully charged car battery instead, your inverter needs 30 amps and above of current from 12 volt power supply
Jul 20, 2013 | Televison & Video
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
I have 8000 miles on my Tucson check engine light came on at start up this morning...gas cap is tight...no problems?????
there are over 200 reasons for the check engine light to come on, the gas tank cap is just one of them, this light and the problem that turned it on are most likely covered under the federal emission warranty, contact the dealer. see trouble code list below for some of the probelems that cause a check enghine light.
P1100 Map Sensor - Malfunction
P1101 Map Sensor - Abnormal
P1102 Map Sensor - Low Input
P1103 Map Sensor - High Input
P1104 Air Flow
P1105 Air Flow - Abnormal
P1106 Air Flow - Low Input
P1107 Air Flow - High Input
P1108 Fuel Pump
P1109 Fuel Pump - Abnormal
P1110 Fuel Pump - Stuck On
P1110 ETS System - Malfunction
P1111 Fuel Pump - Electrical
P1112 Manifold Differential Pressure Sensor
P1112 VGT Actuator - Malfunction
P1113 Manifold Differential Pressure Sensor - Abnormal
P1114 Manifold Differential Pressure Sensor - Low
P1115 Coolant Temperature Input - Abnormal
P1116 Boost Pressure Sensor - Malfunction
P1118 ETS Motor - Malfunction
P1119 Inlet Metering Valve Control
P1120 Electric Governor - Malfunction
P1120 Inlet Metering Valve Malfunction
P1121 APS PWM Output Circuit Malfunction
P1121 Throttle Position Input - Abnormal
P1122 Boost Pressure Control Valve
P1123 Fuel System Rich - Idle
P1123 Timer Position Sensor - Malfunction
P1124 Fuel System Lean - Idle
P1125 Fuel Press Sensor1
P1126 Fuel Press Sensor2
P1127 Fuel System Rich - Part Load
P1127 Control Sleeve Position Sensor
P1128 Fuel System Lean - Part Load
P1130 Start Solenoid- Malfunction
P1131 Injection Quantity Adjust
P1134 O2s Transition Time(B1/S1)
P1135 Injection Timing Servo
P1140 Inlet Air Temperature Sensor Malfunction
P1141 Slow Duty Solenoid- Malfunction
P1145 Main Duty Solenoid- Malfunction
P1146 Idle Co Potentiometer
P1147 Accelerator Position Sensor (ETS) Circuit
P1150 Barometric Pressure Sensor Malfunction
P1151 Accelerator Position Sensor (EMS) Circuit
P1152 Accelerator Position Circuit-Low Input
P1153 Accelerator Position Circuit-High Input
P1154 O2s Transition Time(B2/S1)
P1155 Limp Home Valve- Malfunction
P1159 Variable Induction System
P1162 High Pressure Pump & Fuel Line
P1166 O2s (B1) Control Adaptation
P1166 Limit O2s Lambda Control (B1)
P1167 O2s (B2) Control Adaptation
P1167 Limit O2s Lambda Control (B2)
P1168 O2s (B1/S2) Heater Power
P1169 O2s (B2/S2) Heater Power
P1170 ECM (Barometric Pressure Sensor)
P1171 ETS Valve Stuck - Open
P1172 ETS Improper Motor Current
P1173 ETS Target Following Malfunction
P1174 ETS Valve Stuck - Close #1
P1175 ETS Valve Stuck - Close #2
P1176 ETS Motor Open/Short #1
P1177 ETS Motor Open/Short #2
P1178 ETS Motor Power - Open
P1179 ETS Position F/B-Mismatch
P1180 O2 S1 Heater Circuit- Malfunction
P1180 Fuel Pressure Regulator - Malfunction
P1181 Fuel Pressure Monitoring
P1182 O2 S2 Heater Circuit - Malfunction
P1182 Fuel Pressure Regulator - Short
P1183 Fuel Pressure Regulator - Open
P1184 O2s No Activity (B1/S2)
P1184 Fuel Pressure Regulator - Power
P1185 Fuel Position - Excessive
P1186 Fuel Pressure - Too Low
P1187 Regulator Valve - Stuck
P1188 Fuel Pressure - Leakage
P1189 Governor Deviation
P1190 Intake Throttle Actuator
P1191 ETS Limp Home Valve On
P1192 Limp home - Target Follow Malfunction
P1193 ETS Limp Home - Low Rpm
P1194 Limp Home - TPS2 Position Malfunction
P1195 Limp Home - Target Follow Delay
P1196 ETS Limp Home - Close Stuck
P1300 Spark Timing Adjust Signal
P1300 Injector Specific Data Fault
P1300 Synchronization Error-CKP/CMP
P1301 TDC Sensor - Abnormal
P1302 TDC Sensor - Low Input
P1303 TDC Sensor - High Input
P1304 Phase Sensor
P1305 Phase Sensor - Abnormal
P1306 Phase Sensor - Low Input
P1307 Phase Sensor - High Input
P1307 Accelerator Sensor - Range/Performance
P1308 Ignition Coil.1
P1308 Accelerator Sensor - Low
P1308 Accelerator Sensor Circuit - Low
P1309 Ignition Coil.1 - Abnormal
P1309 Accelerator Sensor - High
P1309 Accelerator Sensor Circuit - High
P1310 Ignition Coil.1 - Low Output
P1310 Injection Control Circuit Fault
P1311 Ignition Coil.1 - High Output
P1312 Ignition Coil.2
P1313 Ignition Coil.2 - Abnormal
P1314 Ignition Coil.2 - Low Output
P1315 Ignition Coil.2 - High Output
P1316 Ignition Coil.3
P1317 Ignition Coil.3 - Abnormal
P1318 Ignition Coil.3 - Low Output
P1319 Ignition Coil.3 - High Output
P1320 Ignition Coil.4
P1321 Ignition Coil.4 - Abnormal
P1321 Glow Indicator Lamp - Short
P1322 Ignition Coil.4 - Low Output
P1322 Glow Indicator Lamp - Open
P1323 Ignition Coil.4 - High Output
P1324 Glow Relay - Malfunction
P1325 Glow Relay - Abnormal
P1325 Glow Relay
P1326 Glow Relay - Stuck On
P1326 Glow Relay - Short
P1327 Glow Relay - Electrical
P1327 Glow Relay - Open
P1330 Spark Timing Adjust Signal
P1331 #1 MF Signal Line Short
P1332 #2 MF Signal Line Short
P1333 #3 MF Signal Line Short
P1334 #4 MF Signal Line Short
P1335 #5 MF Signal Line Short
P1336 #6 MF Signal Line Short
P1337 #7 MF Signal Line Short
P1338 #8 MF Signal Line Short
P1340 IFS 2 Open
Jun 16, 2009 | 2006 Hyundai Tucson
No kick
It can only be a few things...either it overheated and is in a protection mode...the amp went out... the input line is not supplying input...or the output line is not supplying output. If the input is good...the output that goes from the amp to the kicker itself may have came unplugged. If that is not the case, it may have overheated.
May 30, 2009 | ButtKicker LFE Kit Subwoofer
New Dual XIA3145 2/1 LED glows red, guide claims speaker problem
look at these and only these... power or ground...either your power wire has grounded out somewhere (ud be surprised) or youdont have a good enough ground....i would check the ground first....hopefully this helps
Jan 27, 2009 | Dual (DBXPA6100) Car Audio Amplifier
Computers & Internet Logo
90 people viewed this question
Top Emerson Computers & Internet Experts
Stan Skaggs
Stan Skaggs
ray gallant
FireballXL55
Are you an Emerson Computer and Internet Expert? Answer questions, earn points and help others
