Newly installed York Horizontal 96%+ 2 Stage FAU, not lighting, no fan/ blower, green blinking ststus light on control board
    Problem Solver:
  • 6 Answers
I would say your motherboard is out. If it is still under warranty, then you can just call York. If it isn't it is a little pricey to get fixed.
Posted on Mar 26, 2011
Fan blower not blowing
Most likely need a new blower motor resistor
Aug 04, 2014 | 2001 BMW 325Ci
I cannot get power to bring the induction fan on. I have a solid red indicator light.
Solid red is normal, no call for heat. Try jumping (in the FAU) between the R and W thermostat terminals on the circuit board. Be sure when you do that the interlock safety switch is on delivering power to the heater, the red light is on. Also be careful not to touch the R side to any ground, it may blow a fuse within the circuit board.
If that works, try jumping from the thermostat itself (remove the thermostat and jump the red and white wires) if that works, your thermostat has failed... replace.
If jumping the terminals in the FAU fails to run the inducer fan I suggest you call a technician, as something in the circuitry has failed and will probably need to be replaced.
If jumping from the thermostat wires fails, then the wire is broken somewhere between the thermostat and the FAU (either by literal break, or a signal interruption... like a security system or zoning system).
Good luck.
Oct 05, 2011 | Goodman GMS90703BXA Heater
Have a rheem 90 plus gas furnace, the problem is that when you call for cooling the indoor blower does not come on. on the control board there are 2 green lights and one orange light. the top green ligt is...
Trunthe fan from the automatic position to the on position, if the blower does not come on then you
might have a relay problem. The relay is built into the
board, you may have to replace the board.
Jun 14, 2010 | Heating & Cooling
The AC button light blinks on and off. AC won't
When the light is blinking that means there is a code in the system you will have to take it to a shop and have the codes read. Sometimes "Jiffy Lube" or "Rapid Oil Change" can read the code for but they won't fix it. If the blower motor only runs on high, the blower motor resistor is bad. When you put the fan switch on high it puts full voltage to the fan motor (blower motor) when the fan switch is in any other position, the voltage is reduced by the resistor causing the motor to run at slower speeds. The two problems are probably a result of the resistor.
Dec 14, 2009 | 2003 Chevrolet Malibu
The furnace attempt to light, you can see the
The flame sensor is not sensing the flame. Google "flame sensor"
May be an adjustment or control board problem.
Dec 08, 2009 | York Furnace Draft Inducer Blower Fasco #...
In AUTO; blower won't come on when i turn heater/AC on.
most likely the heating speed relay on your furnaces IFC board has failed.Unfortunately the entire IFC must be replaced to repair this. you are in need of a professional service tech. The same control handles the blower fan, ignition system and safeties. Not a do-it-yourself repair as wires in the wrong place could cost you a house.
Dec 18, 2008 | Goodman CKL24AR24 Air Conditioner
Convergence ICs
the green is half controlled by half of each of the convergence Ics meaning green horizontal is controled along with the red and green vertcal is controlled along with the blue Ics. So if you have replaced both Convergencs ICs the problem is most likely a resistor that is in the green circuit. You will need a schematic to locate which resistors are in the green vertical and horizontal convergence circuit
Jun 07, 2008 | Toshiba 55H70 55" Rear Projection...
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
