Question about Vizio P42HD Television
I have a Vizio LCD TV model #VIZIO VW46L FHDTV10A, PART#10239020022, mfg date Jan 2008, serial# LSABIJO211640. On the leftside portion of the screen ther are several vertical lines of different colors. What caused this and how can it be fixed.
  • Anonymous Mar 15, 2014
    removing back panel of vw46l fhdtv10a
  • 2,382 Answers
Hi, vertical lines when the television is on may be related to issues with the television's screen resolution. Resolutions set higher than 1280 by 720 can create visual disturbances on the screen. You can reset the resolution through the control panel's display settings menu. This should correct the issue immediately, although you may need to power the television off and then on again in some cases..
Posted on Mar 26, 2011
VIZIO GALLEVIA modle VIZIO GV47L FHDTV10A
Most plasma TV's have secoundary power boards, witch can be the cause, now I would try if I where you is to unplug it and let it set a hour or two, if that did not work then the tv will need to be looked at locally. The cause can be a bad power board inside the TV witch is a major cause why a Tv would have a power light put no function at all.
Hope this helps if you have any questions as to what parts to buy www.partstore.com is a best resource.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 18, 2011 | LG 42PG20 42 in. Plasma HDTV
I have a 3 year old 46" Vizio TV vw46l fhdtv10a that started having some shading in spots for minutes at a time. After some research I came to the conclusion that changing the T-con board was my best...
Its under the metal frame at the top of the set, follow the LVDS cable, the thick one coming out of the main board to the Tcon board...you will need to remove a couple screws to get the cage off that is over the board
Dec 24, 2017 | Vizio VW46LFHDTV10A 46 in. LCD TV
I have a vizio 46 in lcd model # VW46L FHDTV10A and it started with the whole left side going dark and then it would get better after an hour or two. then about a week later the entire left side of the...
I would suspect the backlight inverter is faulty:
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the BN_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
This could also be the CCFL bulbs that are aging and need replacement. Those are around $20 each for a bulb
Hope this helps! Please rate :)
Mar 14, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
Vizio GV42L 42inch LCD/HDTV
there are several possibilities. first if the unit comes on and the "VIZIO" light turns white, but no picture or sound, then the main control board is most likely the issue. could be the LCD control board(s) depending on model one or two. and ultimately could be the power supply on the upper side....if the "VIZIO" light does NOT turn white, the whole power supply unit is out. after that, would have to scope the circuits to find out. Seems that the control board is the most common and tends to happen on many different sizes. new board will be around $350.00. Might get lucky and find a used one, but it MUST be EXACT part or it wont work right. if you dont find one or want to sell yours for parts, id be interested in the screen. can reach me at kmarlin@grandvalleygolfclub.com. thanks, keith
Jun 27, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42" LCD Screen (VW42L FHDTV10A) Screen is cracked
i have a 42" cracked vizio screen, where can i find a replacement screen?
Jan 17, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio vx32l broken screen.
i have this tv it has screen broging  i want fix screen but what i do ?  my mail is yousaftareen@gmail.com
VIZIO TV MODEL # AND ALL DATA
MODEL NO VIZIOVX32L
HDTV 10A 100-240V-1.5A 60/50HZ
SERIAL NO LSSABBH 1919067
MFG. DATE MY 2007
poless send me enformation
Feb 17, 2008 | Vizio VX32L Television
Vizio tv clean screen
HI sam one have Screen of this TV ? VIZIO screen
MODEL NO VIZIOVX32L
MFG. DATE MY 2007
MY TV SCREEN IS BROKING SO LOLES HALP ME !
MY MAIL IS YOUSAFTAREEN818@GMAIL.COM
OR YOU CAN CALL ME AT 818-744-3794
I AM FROM U.S.A CA ZIP COD IS 91601 I NEED SCREEN FOR THIS TV ......>>>1c26157.jpg
Jan 12, 2008 | Vizio L37 Television
Vizio P42HD Television Logo
370 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
