Question about Alpine CDA-7892 CD Player
I have a CDA 7892 alpine works great but would like the display to be brighter seems a bit dim manual does not say this model can be adjusted or am i missing it any help thanks in advance
    Sergeant:
  • 314 Answers
You didn't specify if you wanted the display brighter in the daytime while headlights are off or if it is too dim when the headlights are on, with respect to the rest of the instrument panel illumination. Too bright is easier to deal with but too dim is tough. If it is always too dim under but daytime and night time conditions the only way to improve brightness would be to very gently disassemble the front panel (easier if it is the removable type) and determine what provides the back lighting. If there are tiny LEDS you could painstakingly add more LEDS or swap them out for brighter LEDS. There could be a lot of guesswork determining if this or that LED was brighter than what is in the unit as built. It may just be easier to live with it as-is.
Posted on Oct 05, 2013
SOURCE: Peripheral's Connex2Car adapter to an Alpine CDA-9851
the alpine should recognize it as a "changer" when you select the source; ie: radio, CD, changer. Sounds simple, but have you turned up the volume on the iPod?
The Alpine adapter is $100, but works great, you can totally control all your iPods functions, and it displays all song info on the Alpine decks display.
Posted on Feb 06, 2008
elecgooroo
  • 57 Answers
SOURCE: i bought a 2002 alpine cda-7892 cd radio i need wiring manual
just run the rca wires from the back of your radio to your amp as well run a direct power wire from your battery to your amp then run a ground wire somewhere on your cars metal surface look for a bolt that you can loosen to whrap the wire around then run a wire from your fuse box tap into a fuse socket that is only powered when the ignition is on you can buy a complete amp wireing kit at pepboys or walmart that will come with instructions good luck....
Posted on Jan 10, 2009
SOURCE: adjust clock on alpine cda-9884
Look on the bottom part of your faceplate and there will be a button with a (F) on it and you hold it then you will figure the rest out. Or just look in your owners manual.
Posted on Feb 09, 2009
SOURCE: Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Posted on Feb 22, 2009
gpgab97
  • 77 Answers
SOURCE: On my Alpine CDA 7892 i have the aux cables right
I believe you need the Alpine KCA-410C - Ai-Net multi-changer/versatile link adapter before you can input from an external source directly.
Posted on May 08, 2009
How do i turn on an alpine cda 792
Press the Source button.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwjehfyp5JfbAhWq3YMKHUVRCRcQFggpMAA&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F5%2F58a5b847-40d6-4050-b9f6-665dcac29113.pdf&usg=AOvVaw0bgzRI_YgcM9HHxL6fTHFp
May 21, 2018 | Alpine Car Audio & Video
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
Alpine da 7892 need to know how to set preset bottons
Below you will find a link to the user manual for your cd player. On page 20, there are instructions on how to set presets.
Click here for manual
Regards,
G33k
May 16, 2011 | Alpine CDA-7892 CD Player
How can I get my ipod to work on the Alpine CDA-7892?
Ai-NET/RCA Interface cable (KCA-121B)
Converts the changer port to RCAs... then an RCA to female 3.5mm female adapter.
Or an FM Modulator.
Thanks for using FixYa - a 4 thumbs rating is appreciated for answering your FREE question.
Dec 26, 2009 | Alpine CDA-7892 CD Player
Need wiring diagram for cda-7892
Hi and welcome to FixYa.
Below is the wiring diagram for an Alpine CDA-7892.
It was captured from the user's manual available here.
Good luck and thank you for asking FixYa.
Nov 10, 2009 | Alpine CDA-7892 CD Player
Is the CDA-7892 supposed to have a backlight when off?
Hello ckabee1,
The "illumination" lead on the CDA-7892 is ORANGE and terminated with a spade lug. It should be connected to the appropriate instrument panel light lead from the vehicle wiring harness. You can download a copy of the manual here with all of the wiring color codes. If you do not know the vehicle color code, you can probably find it at www.modifiedlife.com. Just click on "Car Stereo Wiring Diagrams" at the top and select your vehicle make, model and year.
Hope this helps.
Jul 11, 2009 | Alpine CDA-7892 CD Player
Alpine cda 7892 cd output
Hve you checked the mute button??? if so then it needs to see a pro as this is a great unit so it should be serviced only by a great tech. I simply love the alpine seris!!!!!great choice in car audio man!
Apr 02, 2006 | Alpine CDA-7892 CD Player
Alpine CDA-7892 CD Player Logo
155 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
