Question about Maytag Refrigerators
I have a Maytag gz2626gekb side by side and the damper door seems to get stuck due to chips of ice forming around it. It jams on the chips of ice. Ive replaced the damper assy already and still experience the problem. Do you have any ideas? I purchased a jazz board and fitted it but it it came up eith a temp' display of '0' degrees and i couldn't adjust it. The chip on the the jazz board said Jazz 14. The one that i took out says Jazz 15. Obviously the jazz boards aren't universal for all models..any help please. Brendan Australia
  • Maytag Master
  • 3,740 Answers
If your air damper door is constantly getting ice forming on it there is a reson for this. This is most oftern caused by an improperly sealed fresh food compartment door gasket, a warped door or improperly adjusted door hinges. Having said that... there can be other causes such as a clogged compartment drain in eaither compartment that forces air to rapidy transfer from one compartment to the other side when one of the doors is opened and the rapid temperature change initiates the rapid air flow and eventual condensation / freezing.
Make sure your compartment drains are clear and the end of the drain tube that terminates in the catch basin under the unit is free of obstructions. (rear fiberboard compressor cover removal required) To cause the rapid air transfer I spoke of above this tube has to be blocked.
If you discover that the compartment drain is clogged with ice.... the only fix / remedy is to perform a manual defrost by unplugging the unit, removing the freezer contents and directing an exteranl fan into the freezer compartment for just over 2 hours. The reason for the 2 hours is that should there be ice in the drain funnel the water in the top of the funnel accumulates on top of the ice and insualtes the ice in the funnel from melting so you just have to wait until it warms up over time.
After perforning this manual defrost... use a vacuum to first attemot to remove any debris from the drain tube end and then put the hose on exhaust and direct air into the end of the compartment drain tube to float out any debris from the compartment drain funnel.
One question I have is why are you changing Jazz boards? Do you suspect you have an Automatic defrosting problem?
Thanks for choosing FixYa,
Kelly
Posted on Mar 26, 2011
The ice maker is making a slight clicking noise and not dumping ice. why?
it sound as the tray should be look into. It can be worn out or crackrd
Jul 03, 2014 | Jenn-Air JCD2389G Side by Side...
How to fix ice build up in freezer
Did you examine the drain behind the rear panel (location #11) and below the evaporator coil in photo HERE and location #20 HERE You will need to tell me how much frost there is on the evaporator coil (location 22) I want you to test the=> 12729129 Defrost Heater Assembly. Check the door seals around both doors. Are the door seals good? I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 11, 2014 | Maytag Refrigerators
Rs 265lbbp fridge is freezing everything fridge portion no ice on coils
This unit has a heater on the damper door. Sometimes the heaters go bad our just weak, causeing the damper door to freezer close. You can try thawing our damper by removing it to see if the issue happens again.
Aug 18, 2012 | Samsung RS265LBBP Side by Side...
Maytag refrigerator GZ2626GEKB is suddenly too cold even on lowest setting
The most likely problem is going to be the air damper is sticking open and too much cold air is entering the refrig.section. The damper is located in the upper left side wall of the refrig.section and very likely the door is stuck open so the damper asm. would need to be replaced. The part number for that damper asm. is 67006251 it could be purchased at your local appliance parts store or online at;
repairclinic.com
apwagner.com
searspartsdirect.com
apdepot.com
partselect.com
GENE
Sep 08, 2011 | Refrigerators
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
The fridge does not seem to be cold.
if just the refrige isnt cold,check the damper door located between the freezer and refrige compartments and see if its open to let in cold air from freezer,if not sometimes they freeze shut and cant operate with temperature setting changes/if nothings cold,then replace the ptc overload relay located on the compressor body,it just unplugs off the compressor
Mar 23, 2010 | Maytag ZigZagW / B Side by Side...
Ice dispenser in door clogged up or frozen
I would contact Hotpoint direct for this one. It sounds like a design fault to me.
What I think may be going on is that the cubes are melting too much, then refreezing lower down.
Set your freezer to -18, and the fridge to +2 and see if that changes things any.
Check seals in that area. Where is the moisture coming from to generate the frosting? - Is the location high in humidity?
Jun 11, 2008 | KitchenAid KSRS25IL Side by Side...
Ice not getting through the door
Seems that the door is jammed or frozzen.
Dec 24, 2007 | Maytag MSD2756G Side by Side Refrigerator
Ice maker
Can you open the door by hand or is it stuck shut? Check this site for a diagram of the area to help you see inside the door mechanism. http://www.partselect.com/MultiModels.aspx?ModelNum=MSD2756G&searchTerm=img_A58-10&RefineSearch=0&imgMfg=Maytag&Page=2
Nov 26, 2006 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
142 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
