Question about Ovens
I have a Kleenmaid TO700X fan forced oven. I believe that is a Brandt oven. the fan at the rear of the stove is inop. the element at the rear failed replaced element and then noticed that fan inop and rotisserie motor inop as well have replaced rear fan motor still no go. have by passed rotisserie motor (joined together wires that go into rotisserie motor) still no go. removed rotisserie motor unable to turn by hand. but do not believe that will not let rear fan not work. checked all relays on circuit board at top of stove all appear to be working can hear tyhem click when you change switch position.
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 13 Answers
    SOURCE: Main fan oven does not work, conventional main oven does work
    The element is where you said and yes it can be replaced without removing the oven. Remove the bacplate from inside the oven and you will see the element and fan. Remove the screws from the element and gently pull it forward then remove the 2 wires and keep hold whilst you fit the new element. Replace screws in the element refit the backplate job done.
    Posted on Jul 29, 2009
    SOURCE: how to replace a kleenmaid brandt dishwasher door handle
    Go to www.espares.co.uk
    Look for "Dishwasher Door Handle Opening Pedal" - Genuine spare part for select Blomberg and Hygena dishwashers.
    This is the part you need for a Kleenmaid/Brandt DW3 dishwasher.
    Posted on Feb 04, 2010
    • 51 Answers
    SOURCE: need a manual for my
    http://www.tradebit.com/filesharing.php/search/0/kleenmaid/0/1
    Posted on Sep 18, 2010
    BarrettDenCo
    • 1772 Answers
    SOURCE: Hi there, I've got a
    Sorry to read about your problem, I hope this helps you out.
    sorry their is no simple fuse for what you are writing about, you may just have defective heat elements.or open thermal switches. and they are not easy to check
    I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    2 Thumbs - Somewhat Helpful
    Posted on Dec 30, 2010
    Main oven not heating up , fan running ,temp light on but no heat
    I suspect that the oven element has failed, to check this, remove cover at rear of oven compartment, there you will see the round oven element, it should feel hot after turning oven on to heat, if it is cold, replace it.
    Feb 28, 2011 | Stoves 720EF Electric Double Oven
    Oven fan not working
    If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
    Feb 25, 2011 | Stoves 720EF Electric Double Oven
    Need a manual for my old fan forced Kleenmaid by brandt oven.......no other model markings on oven
    Sep 15, 2010 | Ovens
    Newworld dfeo 90 main fan oven not heating - fan works! - which part most likely faulty
    If it is an electrically heated fan oven, then I would suspect the oven element has failed, this is at the rear of the oven compartment behind a removeable cover.
    If it is heated by gas, then I do not have an answer for you,as I have no knowledge of gas ovens.
    Hope this helps.
    Jan 30, 2010 | Stoves Ovens
    My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
    Oven functions
    Oven light.
    Upper and lower heating elements.
    (Conventional cooking).
    Upper and lower heating elements with fan.
    (Fan assisted cooking).
    Lower heating element with fan.
    Inner grill heating element.
    (Radiant grill).
    Full grill heating element with fan.
    (Fan grill)
    Rear circular heating element with fan.
    (Fan forced cooking).
    http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
    Oct 10, 2009 | Ovens
    It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
    If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
    To replace: Turn off power!!
    -Remove side racks from oven, then remove rear panel.
    -You should now see fan blade and fan element.
    -You need to remove oven from cavity, then remove rear outer panel.
    -You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
    Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
    Aug 10, 2009 | Smeg Ovens
    Oven not getting hot
    If the fan is working, then the oven element has failed, you need to fit a new element., it is behind a removable cover at rear of oven compartment.
    Jan 25, 2009 | Stoves Premier 600EMa Electric Single Oven
    Oven not heating up
    Hi.
    If the fan is working o/k, then in all probability the fan oven element has failed.
    A common problem with fan assisted ovens.
    It is a fairly easy job to replace same
    Nov 13, 2008 | Baumatic B180 Electric Single Oven
    Ovens Logo
    46 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
