Question about LG LFX25960ST Stainless Steel French Door Refrigerator
My lights inside my fridge won't turn off. It was fine this afternoon and now it's not. It's not even 3 years old. The heat from the bulbs is making the top 2 shelves too warm and I have already been forced to throw a few things out. The lower shelves seem to bee sufficiently cold.
    Problem Solver:
  • 53 Answers
Your Refrigerator light door switch may be broken or damage.
1) Check manually Press the button on hand. Light off or not.
2) Light not off - replace the switch.
3) Light off - Door position or alignment not correct.
Posted on Mar 26, 2011
My 19 year old kitchenaid kbrs21k refrigerator still works fine BUT when i recently crammed too much stuff onto the top shelf i must have broken the plastic light cover which fell on top of the light bulb....
Take the bulb out and check the continuity. Then you should know if there is a fuse that needs replacing. If all is well make sure your new bulb doesn't have a bad element.
Dec 03, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
My microwave bulbs don't work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
Jun 21, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Start-up on RCA HDtvDLP M50WH72SYX12
I can not fix it but I no the type of bulb Siries B Number 270414!
Jan 30, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
242 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
