Question about Jamo I300 Docking Station
What type of ipod is suitable for dock on jamo i300?because i used for iphone 4 but not working
  • 34 Answers
SOURCE: My Jamo i300 will not charge my new ipod nano (4th Gen).
not likely the new 4 gen Ipod has different pin set within its dock connector system for the video output which has made many 3rd party accessories no longer able to charge the ipod but it will still play music
Posted on Jan 26, 2009
technical114
  • 1851 Answers
SOURCE: My Jamo i300 has stopped
Have you tried to unscrew the 10 screws at the back panel of the sub? Theoritally doing this you will have in hand all the electronics except the speaker.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, accept my solution. Please consider leaving a 4-thumbs rating; I'd appreciate it greatly.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Aug 22, 2010
hunter19_46m
  • 7482 Answers
SOURCE: what batteries to put in the jamo i300 remote
Remote Control Battery Replacement
To replace the battery, remove the two screws on back of the
remote and disassemble. It is a "Button" type battery not sure what the number is but look at the battery and find the number on it and replace it with the same style battery
To download a free owners manual go to this website
http://www.jamo.com/na-en/support/owners-manuals/
Posted on Jan 14, 2011
  • 6 Answers
SOURCE: Sony ICF-CS10iP iphone/ ipod dock will not charge
connectors on the dock are probaly faulty return to sony to get repairedv (it will probaly cost) contact sony to arrange
Posted on Feb 25, 2011
  • 1833 Answers
SOURCE: Hi, my Jamo docking system
First make sure that your iPod supports your docking system. Check your electric outlet where you attach your docking system. Check the electric input of the dock, if any loose there. If it will not solve your problem then check the iPod settings and reboot the both. May your iPod software is corrupted.
Posted on May 10, 2011
Tip
How To Connect Your iPhone, iPad, or iPod To The TV
The following devices have support for TV out:
  • iPhone
  • iPad
  • iPod touch
  • iPod nano (3rd generation and later)
  • iPod classic, iPod (5th generation), and iPod photo
Note: Other iPod models may support viewing of photos or slideshows on the iPod display but do not support TV out.
The following docks support TV out when used with an iPod model or iPhone that supports TV out:
  • Apple Universal Dock (requires either the Apple Composite AV Cable or the Apple Component AV Cable-will not work with the iPod AV Cable). Search the store for part number MB125G.
  • iPod Universal Dock or iPod with color display dock (iPod photo dock)
Important: The iPhone dock does not support TV out.
iPod models that support TV out can support viewing on a television in several ways. Use the tables below to see which cables and docks can be used with each iPod model. Check the documentation that came with the cable or iPod for information on how to connect and enable TV out.
Note: If you choose to use a third-party cable, make sure it has the "Works with iPhone" or "Made for iPod" label. Learn more about iPod and iPhone accessories.
All you need to get TV out is a compatible iPhone, iPad, or iPod and the correct cable. If your device works with the component and composite cables, then the choice depends on the TV(s) you will be connecting to.
  • Apple Composite AV Cable (part number MB129LL) will connect any iPhone, iPad, or iPod to your TV using RCA Cables.
  • Apple Component AV Cable (part number MB128LL) will connect any iPhone, iPad, or iPod (except iPod with color display (iPod photo), and iPod (5th generation)) to your TV using Component Cables.
A dock can be a welcome addition if you're going to keep your cables connected to the TV. The Apple Universal Dock includes an Apple Remote so you can pause and adjust the volume from a distance. The docks and cables are sold separately.
on Feb 21, 2011 | Apple iPhone Smartphone
What batteries to put in the jamo i300 remote control
Jan 14, 2011 | Jamo I300 Docking Station
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
Jamo i200 doesn't charge iPod Touch
have you tried changing the charger or charging it through a computer. some chargers are too outdated for the ipod to charge!
Jun 20, 2009 | Jamo I200 Ipod docking station
Jamo i300 dies after powercut
If its out of warranty you might as well open it up , and if your lucky it might only be a fuse to replace , if it is fused inside it will probably have blown before it could do any damage to circiuts . hope this helps
May 25, 2009 | Jamo A 102 HCS 5 System
Jamo i300 docking cradle broken
I've experienced exactly the same problem but by my 1 year old. I have tracked down the Jamo repair centre in the UK - Tele Fringe. Contact them at sales@telefringe.co.uk - They have just advised me that a new i-cradle for the i300 is £72.
Apr 02, 2009 | Electronics - Others
Jan 15, 2009 | Audio Players & Recorders
Jamo I300 Docking Station Logo
195 people viewed this question
Top Jamo Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
