Question about Panasonic Televison & Video
Panasonic TH-50PV700AZ just stopped working. When we tried to turn the TV back on the green light flashes for about 5 seconds then flashes red 7 times consequently. Looks like possible trouble code. The TV now has has no screen or sound. We have also tried unplugging mains, ans restarting but still nothing.
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
jerryg50
  • 1689 Answers
SOURCE: Panasonic 42" Plasma Television 2008 (4-blinks)
I have seen a fault where the Plasma display was giving sparkling green dots, and then the set would shut down after about 10 minutes. After waiting for about 40 minutes, I would re-start and the process would work the same, and then the set would shut down.
I tried freezing the boards one by one with freeze-spray, and heating with a heat gun to see where the thermo fault could be. I had no success.
Fortunately I had access to a scrapper set of the exact same model. After spending many hours with the process if elimination, I worked the fault down to be the screen itself! Unfortunately, with the scrapper set that I had its screen was very weak. Swapping the screens between the two sets proved that the original screen has failed.
I don't want to discourage you. You may be down to the point of what I reached!
Jerry G.
Posted on Feb 10, 2009
SOURCE: Panasonic Model TH-42PZ77U doesn't turn on
I contacted Panasonic and it seems that they will take care of the problem even though the TV is out of the 1 year warranty. They are aware that this is a manufacturing defect, apparently. I'll follow up later to let you know how it turns out.
Posted on Aug 03, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
SuperTech-11
  • 1591 Answers
SOURCE: I have the Philips 50
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, it may eventually stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
utube.pngYou-Tube video "Mm51C_RDIZE" placeholder
utube.png You-Tube video "BNHHrgX_6cs&feature=related" placeholder
(do not delete)
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Mar 25, 2011
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic TH-46PZ85U when i turn on tv does not go on but red power light flashes. What can I do to fix this?
I unplugged the tv from the outlet, waited abut 20 seconds and plugged it back in. I was able to turn the tv back on. But, when I turn it off, and try to turn it back on with the remote, it doesn't always work.
Don't know if it's the power supply going?
May 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic TH42PZ70B
Flashing RED lights in Panasonic TVs means a fatal error code. Unplug the TV, wait 1 minute and replug. If the LED still flashes it needs professional service.
Sep 04, 2008 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
